ray007 Posted July 18, 2010 Share Posted July 18, 2010 hi guys bit of a novice here, trying to do an oil change on my 1jz conversion, cant find where to drain the oil from.... please help,, any advice would be much appreciated Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted July 18, 2010 Share Posted July 18, 2010 ok, underneath the engine is the sump, you should be able to recognice it, its like a small bucket sticking out from the bottom. theres a 1 bolt in it, usually a 17. undo that and all the oil will flow out of it. Quote Link to comment Share on other sites More sharing options...
bignum Posted July 18, 2010 Share Posted July 18, 2010 Isn`t there a forum for lexus owners:p Quote Link to comment Share on other sites More sharing options...
ray007 Posted July 18, 2010 Author Share Posted July 18, 2010 ok, underneath the engine is the sump, you should be able to recognice it, its like a small bucket sticking out from the bottom. theres a 1 bolt in it, usually a 17. undo that and all the oil will flow out of it. ah i just see your reply, i found it anyway thanks bro Quote Link to comment Share on other sites More sharing options...
ray007 Posted July 18, 2010 Author Share Posted July 18, 2010 Isn`t there a forum for lexus owners:p there is but my 1jz lump is in the jza80, so im an mkiv supra owner not a lexus owner:p Quote Link to comment Share on other sites More sharing options...
trinitom Posted July 19, 2010 Share Posted July 19, 2010 Just make sure you know where the boot release catch is! Quote Link to comment Share on other sites More sharing options...
