supra steve Posted July 17, 2010 Share Posted July 17, 2010 was on the rr the other day and my afr dropped as it should do when turbo spooled up only to peak twice,this was running at 1.3 bar.had a look at the map sensor and think its a standard 1,can anyone tell me if the serial numbers on the stock are 89452-12080.heres a list of my engine mods and if stock can anyone tell me which map sensor would be adequate.thanks Greddy e-manage ECU polished phr gt60 turbo siemens 850cc injectors blitz fmic hks gt external wastegate 50mm phr 5/8 fuel rail fluidlyne aluminium radiator with wetter water hks supersequential dump valve twin walbro fuel pumps iridium spark plugs aluminium fmic piping steel braided fuel lines aeromotive fuel pressure regulator K&N air intake with 4" polished tube aluminium upper radiator hose rss straight through de cat ceramic coated downpipe,mid pipe and torbo exhaust hks ceramic coated manifold blitz boost controller blitz turbo timer Quote Link to comment Share on other sites More sharing options...
supra steve Posted July 19, 2010 Author Share Posted July 19, 2010 bump:) Quote Link to comment Share on other sites More sharing options...
