Ls400 brakes
ruishy1
  • 3 weeks later...
are they a direct fit into the supra hub, obviously you have to cut away the metal dust covers but is there any other mods needed.
You need to file away a bit of the cast on the caliper, all will become clear when you go to fit these, you'll also need caliper bolts off an LS400, there is a thread on here somewhere with the part number for them :)
The filing will take all off five minutes and that is the only thing needed! :)
I have the caliper bolts they came with the brakes ,so that a plus then , I will be trying them this week so ill post up what is needed as in any mods to make them fit , i was not sure if they would fit straight on thats why i did not send them straight off for recondictioning . Measure twice cut once as they say . Rich.
