UK spec wiring loom on j spec engine
blue-luck
i have just finished building one of my supra's and have come across this problem..
i have a UK spec engine wiring loom and also a UK spec ECU running a j-spec TT engine.
when i first put it all together in the car, i couldnt get it started, then i borrowed a UK resister pack for the injectors and connected that to the loom, and the car fired up, but it doesnt idle well, feels like its missing. Also have black smoke coming out the exhaust. i've checked all the plugs/coil packs and injectors, and everything seems to be working as they should. when i took this engine out of the car it was originally in, it ran perfect, no smoke, no missing..So i can only imagine its something to do with the loom?? or maybe its because UK's have 550 injectors and j-specs have 440's??
any advice would be appeciated
thanks
Does the uk spec run the same electronic components to the J-spec, if not thats your problem.
No, UK loom is slightly different... in at least that the UK has a MAF sensor amongst other things....
UK injectors are also 550s and not 440s....
when i connect the MAF sensor, the doesnt start, and even when i connect it while the car is running, it cuts off.. but when disconnected its ok.. i've got a j spec engine, so only 440's..maybe need the 550's..
is there a way to bypass the resistor pack and keep the 440's??
thanks..
thanks..
The 550's are meant for the UK ECU, so don't put the 440s in. With the MAF disconnected it is probably running in limp-mode....
I don't mean this with any offence... but surely with the troubles you are having here that it would be best in the hands of someone knowledgeable?
i know..:)
but trying to do what i can..as i have a couple of supra's, so i can use parts off each of them as process of elimination, otherwise if i was to take it somewhere, i might have to keep buying different parts which might not help..
thanks..
i know..:)
thanks..
Can you not just use a j-spec loom, keep the 440s, no resistor, j-spec ecu then?
this is the main problem, left hand drive loom, and as far as i know all left hand drive looms are UK/Euro spec..
i was told that the resistor pack can be bypassed, but i'm not sure how..
the easiest thing would be to get some 550's but i need to find some first, so i thought if i can get it sorted by bypassing the resistor pack and putting in a jap ecu, and see if that works, as i can have a jap ecu anyway..just dont know how to bypass the resistor pack..
thanks
This thread might be of some use for the resistor pack bypass:
http://www.supraforums.com/forum/showthread.php?t=572776
If you're running the UK Spec ECU on a J-Spec you will definately need the 550s (simply bypassing the resistor pack is not enough - the UK ECU is designed for the bigger injectors which will result in you running lean and potentially killing your engine if you bypass and use 440s) the MAF and the resistor pack. Other differences such as the second O2 sensor and the EGR system can be ignored.
thanks for that, but cant really figure it out..
just need a diagram of which wires to join..
thanks
