Stonkin Posted July 15, 2010 Share Posted July 15, 2010 Hi, found out the blowing issue i have is a cracked manifold along one of the original welds. All the top studs were tight and fine but all of the bottom were finger loose and one of them totally missing. One of the support bars has also cracked. Would i be ok to get it tig welded to save replacing? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted July 15, 2010 Share Posted July 15, 2010 everyones dropping like flies, i was looking forward to seeing and meeting you at pod dude.... im sure it can be welded back up though?? Link to comment Share on other sites More sharing options...
Stonkin Posted July 15, 2010 Author Share Posted July 15, 2010 I'm not missing pod this year thats why i want it welded if it will hold Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 15, 2010 Share Posted July 15, 2010 As a VERY temporary fix it could be welded but it will crack again, and more quickly than before. The cracks, and thus the weld repair will be contaminated with carbon now. Look to bin it and find something properly made long term. Link to comment Share on other sites More sharing options...
Rich Posted July 15, 2010 Share Posted July 15, 2010 Is it an XS flower one? Link to comment Share on other sites More sharing options...
matt k Posted July 15, 2010 Share Posted July 15, 2010 Which manifold is it? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted July 15, 2010 Share Posted July 15, 2010 As a VERY temporary fix it could be welded but it will crack again, and more quickly than before. The cracks, and thus the weld repair will be contaminated with carbon now. Look to bin it and find something properly made long term. i agree with this but i think you should get it welded atleast you can make pod, then buy a new one after Link to comment Share on other sites More sharing options...
Stonkin Posted July 15, 2010 Author Share Posted July 15, 2010 Thought that would be the case Chris. Would be nice if it could last for the summer anyway, well, at least the pod Its an obx. Charlie had it 'reworked' in some way i believe but not sure what Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 15, 2010 Share Posted July 15, 2010 From what I can see that rod to the turbo flange could be doing more harm than good, I would probably chop it off when you get it welded. MIG with a stainless filler wire would be my choice for fixing it (temporarily) It should last a bit longer, certainly get you through the race weekend, with luck Link to comment Share on other sites More sharing options...
Stonkin Posted July 15, 2010 Author Share Posted July 15, 2010 Theres one of those rods on each side of the flange Chris. I thought they were supposed to be a good idea? Thanks for your help Link to comment Share on other sites More sharing options...
Ian C Posted July 15, 2010 Share Posted July 15, 2010 That's an old turbosh1t one isn't it. I was always dubious of those rods due to the expansion rates when it got hot, and also wasn't really sure what it was trying to support when it's a vertical load on a lateral bar. Still at least it was cheap Link to comment Share on other sites More sharing options...
Stonkin Posted July 16, 2010 Author Share Posted July 16, 2010 Pretty certain Charlie said it was an obx Ian, although could be what turbofit were also using. Its gone off to be welded anyway, but if i wanted to replace this, what would be my options? Looking at the pic its undivided right? If i bought a new manifold could the wastegate and screamer pipe i have be used and would it all bolt straight together and fit or is fabrication work likely to be needed? Just trying to gather my options for when it needs replacing. Link to comment Share on other sites More sharing options...
JamieP Posted July 16, 2010 Share Posted July 16, 2010 Not many manifolds sit straight with the engine like the obx does, if you go with another manifold you will have fitment issues with the downpipe, best option might just be to go with another obx. Link to comment Share on other sites More sharing options...
Stonkin Posted July 16, 2010 Author Share Posted July 16, 2010 Ok, cheers Jamie. Should have it back next w'end, so at least i can put the dash and dials back together and it will look like a car again. It just needs to hold together for some abuse before pod to get used to it again and make sure its running ok and then at pod Link to comment Share on other sites More sharing options...
matt k Posted July 16, 2010 Share Posted July 16, 2010 Or modify the downpipe not expensive Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 16, 2010 Share Posted July 16, 2010 That's an old turbosh1t one isn't it. I was always dubious of those rods due to the expansion rates when it got hot, and also wasn't really sure what it was trying to support when it's a vertical load on a lateral bar. Still at least it was cheap Agreed, they aren't doing anything useful, in fact they are probably adding stress. Link to comment Share on other sites More sharing options...
Stonkin Posted July 16, 2010 Author Share Posted July 16, 2010 So support braces in general are a good idea, but these ones are crap due to their design/location? Should i definetly contact the welder and get them removed, need to be quite quick with it if so as they have it now Link to comment Share on other sites More sharing options...
supra matt Posted July 16, 2010 Share Posted July 16, 2010 Did you have this heat wraped mate? As my his one has cracked in the same way . Link to comment Share on other sites More sharing options...
Stonkin Posted July 16, 2010 Author Share Posted July 16, 2010 Hi Matt, yes it was all heat wrapped and i plan to re wrap it once it comes back Link to comment Share on other sites More sharing options...
adnanshah247 Posted July 16, 2010 Share Posted July 16, 2010 XS buddy. there crap. i cracked mine twice. Link to comment Share on other sites More sharing options...
