JACDAV Posted July 15, 2010 Share Posted July 15, 2010 (edited) How much boost before upgrading fuel system? Has it any influence on the fuel system that the car is converted to single turbo? Does it not require the same fuel when boosting with 1 bar if the engine is twin or it is single? Thanks on advance Edited July 16, 2010 by JACDAV (see edit history) Link to comment Share on other sites More sharing options...
bignum Posted July 15, 2010 Share Posted July 15, 2010 If you work on hp levels you won`t go far wrong, you can`t really go on boost pressure once you change the turbos from stock. A 67mm single @ 1 bar should be around 450 fwhp whereas stock twins maybe 350. Import 440`s fuel system(upgraded pump) is good for approx 420fwhp, Uk/euro 550`s fuel system(with standard pump) is good for approx 500 fwhp, This is without pushing fuel pressures to crazy levels btw Link to comment Share on other sites More sharing options...
JACDAV Posted July 16, 2010 Author Share Posted July 16, 2010 Thanks a lot. How can I see that my injectors is 550? btw. It´s a euro spec. Link to comment Share on other sites More sharing options...
kill1308 Posted July 16, 2010 Share Posted July 16, 2010 If it's a Euro spec you should already have 550cc injectors. I'm sure someone else will be able to confirm this either way Link to comment Share on other sites More sharing options...
Nic Posted July 16, 2010 Share Posted July 16, 2010 (edited) Thanks a lot. How can I see that my injectors is 550? btw. It´s a euro spec. If it's a Euro spec Supra it will have 550cc injectors and higher flow fuel pump. In terms of how much boost you can run, this will depend on the turbo being used. Whoever is mapping the car will be able to determine the limits of your fuel system. Edited July 16, 2010 by Nic (see edit history) Link to comment Share on other sites More sharing options...
