Check engine light
Guest PrEEsten
Guest PrEEsten
Have a small problem, my check engine light dosen't come on when i start my car, been looking around but cant find anyone with that problem.
Quite likely to have dry joints on the small PCB that the bulbs are soldered too. Try giving it a good tap on top of the light cluster and see if that one comes on or flickers as that may give you a clue. If it is that then its and easy soldering fix.
