1jz emanage blue splicing help
johnd-mkiv
Been asking on a few forums about this now but not much help
I have a 1jz with the following ecu pin outs
I have an emanage blue that I need to cut an splice in, fairly sure I have that sorted, its the injector harness thats confusing me. The 1jz has paired injectors when going back to the ecu (can some one explain why they do this) they are shown
x11
x12
x25
in the diagram above.
when looking on the greddy site http://www.greddy.com/upload/file/e-manage_Blue_Install.pdf page 23 it shows the pairing to be
6 cylinder engine with 3 signal injector wire)
Inj channel 1
--------------------> ECU #1
Inj channel 2
Inj channel 3
-------------------> ECU #2
Inj channel 4
Inj channel 5
-------------------> ECU #3
Inj channel 6
is this the correct way to wire up
I have been given other links but theres two other ways on there all seem to be runners which is confusing me :blink:
http://www.supramania.com/forums/sho...eManage-on-1JZ
http://www.toymods.org.au/forums/arc...p/t-57012.html
http://www.skylinesaustralia.com/for...ed&pid=5107767
http://www.supraforums.com/forum/sho...d.php?t=565295
Help me please :D
