dr_jekyll Posted July 12, 2010 Share Posted July 12, 2010 just a bit of bordum thinking from me but, apart from the obvious exhaust tuning what determins the engine sound of a car. for instance a ferrari f430 v8 revs to around 8k i belive and has a high pitched truly awsome sound a ls6 can rev to around 8k (with tuning) but has a completely different sound harsher almost more mechanical and pure. so why do different engines with the same configuration that can rev to similar heights have so many different sounds. Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 12, 2010 Share Posted July 12, 2010 I imagine the Ferrari is a flat plane crank and the LS6 a cross plane crank Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 12, 2010 Author Share Posted July 12, 2010 I imagine the Ferrari is a flat plane crank and the LS6 a cross plane crank oh ofcorse. whats a flat plain crank? and whats a cross plain crank? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 12, 2010 Share Posted July 12, 2010 All to do with degrees of revolution of the cranbk vs firing order. All you ever need to know http://www.projectm71.com/Cross_FlatPlane.htm Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 13, 2010 Share Posted July 13, 2010 Cam timing makes a big difference as does compression ratio. Induction noise, or lack of also affects overall sound. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 13, 2010 Author Share Posted July 13, 2010 so literally they are lots of factors apart from how much gas is being pushed down some pipe. i was at silverstone on the weekend and those f1 engines sound insane as do the gp2 engines. Quote Link to comment Share on other sites More sharing options...
