stinboy Posted July 11, 2010 Share Posted July 11, 2010 Hey all. Took the car out for a spin this morning and I have a problem under boost. The 'whooshing' sound has become incredibly loud under even the smallest amount of pressure. I suspected a loose hose so stopped and checked but couldn't see a problem. I tried to stay off boost going home, but when I did give it a tickle the boost gauge is reading 0.7bar as normal - surely it would be far lower if there was a leak? Spent this afternoon seaching the forum and so have checked the intercooler pipes to ensure they are intact and they seem to be. Just taken it out again up the road and back and the problem hasn't magically diappeared. Lots of whooshing, boost gauge normal and no noticable dip in power. Just had the bonnet up as well forlornly looking for anthing odd and when the turbo timer cut the engine there was an audible burping sound from the turbos! Help I'm totally stumped!!!! Quote Link to comment Share on other sites More sharing options...
richarde7927 Posted July 11, 2010 Share Posted July 11, 2010 thats a good one i had this but i had no boost as i had an intercooler pipe off . Have a look at the smaller pipes around the turbo , if its a smaller pipe off you could get the noise , but as its a small pipe no drop in boost . is your air filter and pipe work still on ok ? get some one to rev the car for you and you have a look around for the source of the noise . Rich. Quote Link to comment Share on other sites More sharing options...
stinboy Posted July 11, 2010 Author Share Posted July 11, 2010 Cheers Rich No prob with the air filter but i'll check the smaller pipework again in the morning Quote Link to comment Share on other sites More sharing options...
stinboy Posted July 12, 2010 Author Share Posted July 12, 2010 Rechecked all hoses and still can't find any off or any cracks. Thought one of the intercooler pipes didn't look quite flush so reconnected it and still no joy. Revving the engine would be ideal but as the turbos don't spool i can't pinpoint the source of the noise that way. I'm at a bit of a loss as to what to do next really.... Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 12, 2010 Share Posted July 12, 2010 Check the turbo blade tips for damage and the shaft for play, might be it's hitting the casing slightly, causing the noise but otherwise still producing boost. Quote Link to comment Share on other sites More sharing options...
stinboy Posted July 12, 2010 Author Share Posted July 12, 2010 Ok - is there an easy way of doing this without taking things to bits. I'm not the most technical i'm afraid.... Quote Link to comment Share on other sites More sharing options...
stinboy Posted July 12, 2010 Author Share Posted July 12, 2010 It's definitely boosting fine but the noise is definitely a whooshy one. I'm clutching at straws now - could it be the BOV? Sorry for the constant posting about this folks but i'm at my wits end.... Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 12, 2010 Share Posted July 12, 2010 Ok - is there an easy way of doing this without taking things to bits. I'm not the most technical i'm afraid.... You only have to take the hose off the front of the turbo, probably one jubilee clip If it's wooshing though, you've probably got a stuck BOV or a leak. The turbo may be working harder to keep pressure up despite the leak. Quote Link to comment Share on other sites More sharing options...
