Titan Anti-roll bars
T2 MSW
Just opened the box up and you get with the rollbars replacement mounts and bushes.
The mounts have a bleed valve on them, whats this for? I assume when you grease them up its a bleed valve for any excess grease?
Also the flat metal plate, is this to go under the mount\bush where it mounts to the subframe?
Also being ajustable, I assume the outside is the softest and the inside is the hardest?
Cheers
Edited by T2 MSW (see edit history)
