N/A spark plugs
LOGIE
Same plug, different gap;
(6341) = BKR5EIX
(5464) = BKR5EIX-11
The '-11' part means that they are pre-gapped to 1.1mm (The correct gap for an NA supra). I'm not sure what gap the 6341 is but i know that you're not supposed to re-gap iridium spark plugs as the tips can snap.
Quoted from the spark plug FAQ - "Iridiums should always come pregapped correctly - altering the gap will cause damage. If you test the gap and it isn't correct return them to the stockist and check they got in the right version."
HTH
