Guest rhd_2jz Posted July 9, 2010 Share Posted July 9, 2010 Whats the best way to go about pressing the diff ear bushings? I was a little skeptical about just pushing on the steel insert but if thats how its done ill give it a whirl... just checking to see if anyone has had experiences with this. Also removing the front sub frame bushings. any input would be great thanks in advance!! Quote Link to comment Share on other sites More sharing options...
dude Posted July 9, 2010 Share Posted July 9, 2010 Ive always found a bit of heat to be your friend here, any rubber bush if you play a torch on the housing will go greasy and virtually fall out, likewise if you have a metal bodied bush and heat the rubber inside that will push out leaving the sleeve which you can then cut a slot in and push out easily. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 9, 2010 Share Posted July 9, 2010 I concur with Dude. Smoky and smelly, but does the job. (Welding torch, not John.... ) Quote Link to comment Share on other sites More sharing options...
