Stratty Posted July 8, 2010 Share Posted July 8, 2010 I have searched this issue and gone through all the relevant threads but due to my lack of knowledge don't quite understand what needs to be done. I had a Competition Stage 4 clutch fitted (new release bearing also) when I went NA-TT however; there is quite a loud squeeking/whine noise coming from the clutch when I release the pedal. This sin't your normal clutch pedal noise. Whilst reading through the paperwork that came with the clutch, it says that the clutch must be adjusted when you hit 750 miles. I am there abouts now and can feel that the bite is almost at the end of the pedal before I hit the free play. Do you think this may be why the noise is coming from the clutch? Also, which bit do you think needs adjusting to change the bite mark? Thanks Simon Quote Link to comment Share on other sites More sharing options...
dive_popo Posted July 8, 2010 Share Posted July 8, 2010 I know that light flywheel makes some noise, but never tested I have an auto... Good luck with the research Pete Quote Link to comment Share on other sites More sharing options...
