wesmi01 Posted December 14, 2002 Share Posted December 14, 2002 Chaps, What BHP do you think I have, im the lucky chap (well it's still making all the right noises) that bought Grahams car. It's running at 1.2 bar, hopefully soon 1.3 with the non cat down pipe fitted!!!! Hybrid Turbos (larger compressor and steel internals) Blitz Access ECU HKS EVC4 Boost Controller HKS 'R' Spec FMIC (Good for 860bhp) HKS Cams 256 In, 264 Ex ERL Water Injection HKS Super Powerflow Induction Kit (Mushroom) TDI Uprated fuel pump able to deliver 25%-65% more fuel than UK Spec CentreForce Heavy duty clutch Racelogic Adjustable traction control + launch Super Drager 'Priest' exhaust (Fully SS) B&M Short Shift Kit, stock shifter and leather gear knob available HKS Rear cat replacement pipe Chris Wilson Front Cat replacement pipe (not fitted) HKS Sequential Super Blow-Off (dump) Valve Greddy boost gauge in stock clock position Quote Link to comment Share on other sites More sharing options...
Thorin Posted December 14, 2002 Share Posted December 14, 2002 I reckon about 350rwhp? Quote Link to comment Share on other sites More sharing options...
Paul Posted December 14, 2002 Share Posted December 14, 2002 23 ?? No, I give in, go on tell us then Paul Quote Link to comment Share on other sites More sharing options...
Paul Posted December 14, 2002 Share Posted December 14, 2002 What about...................37?? Quote Link to comment Share on other sites More sharing options...
Alex Posted December 14, 2002 Share Posted December 14, 2002 I believe this car has an HKS FRONT PIPE replacement - coulddn't see it listed there - if it has this has a 3" straight thru pipe. If you then fit a CW Decat pipe you will experience 1.4+ bar which you don't have the fueling for. You will have to fit a restrictor ring (which you can source from CW). to keep the boost down to 1.2. The next thing you must look into upgrading is the fueling. Graham's got the car into a superb state of tune...now to top it off and extract its potential!!! I would get a set of 550+ injectors and something like a Greddy E-manage to control the fueling (nic on this forum has had good results with this fairly unknown piece of kit) For more info on upgrading the fuelling do a search!! Still congrats on the purchase - I'm jealous! Quote Link to comment Share on other sites More sharing options...
GavinL Posted December 14, 2002 Share Posted December 14, 2002 Depends on the spec of the turbos, there are all manner of hybrid turbos around some of which are only a small increase over the stock items. Bring it up to Santa Pod next year and see what it does in the real world. Quote Link to comment Share on other sites More sharing options...
Alex Posted December 14, 2002 Share Posted December 14, 2002 400 at the crank...about 12.8 at santa pod! As Gavin says make sure you're at the Supra shootout on the 26th of Jan. Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted December 14, 2002 Share Posted December 14, 2002 Take it along to G-Force in Aylesbury, they'll be able to tell you Quote Link to comment Share on other sites More sharing options...
Nic Posted December 14, 2002 Share Posted December 14, 2002 Alex, I think the Greddy e-manage is only available in Japanese so could be a bit tricky to set up over there. Quote Link to comment Share on other sites More sharing options...
GavinL Posted December 14, 2002 Share Posted December 14, 2002 Originally posted by Nic Alex, I think the Greddy e-manage is only available in Japanese so could be a bit tricky to set up over there. There are US versions, I happened to be reading about it today. Quote Link to comment Share on other sites More sharing options...
Graham Rudd Posted December 15, 2002 Share Posted December 15, 2002 Please, please, please get a restrictor ring before you put that pipe on! It WILL overboost and not by a small amount, we're talking upwards of 1.9 bar here, I kid you not. As for the BHP, I never bothered getting it dynoed, I figure you can only probably end up dissappointed doing that. Surely its quick enough!? Quote Link to comment Share on other sites More sharing options...
wesmi01 Posted December 15, 2002 Author Share Posted December 15, 2002 Ow yes i certainly will get the ring. Could I take it to 1.3 bar with the present setup? It's fast but after being in ryan's beast I must have as much sensible power as possible!!!!! lol Quote Link to comment Share on other sites More sharing options...
Alex Posted December 15, 2002 Share Posted December 15, 2002 Originally posted by wesmi01 Ow yes i certainly will get the ring. Could I take it to 1.3 bar with the present setup? It's fast but after being in ryan's beast I must have as much sensible power as possible!!!!! lol NO Infact I would not recommend more than 1bar till you do the fueling. Look at it this way Toyota saw the need to replace the j-spec fueling to run 326bhp on the UK/Euro/US spec supra's...asd you're trying to run 400+ on the j-spec...it doesn't take a genius to work out that it just isn't going to work. But if you feel the need to test it at 1.3 bar, a new engine will cost 5k+ - if you're lucky you can find a decent used one...a fuel system is much much less than that! Quote Link to comment Share on other sites More sharing options...
GavinL Posted December 15, 2002 Share Posted December 15, 2002 Originally posted by Alex Holdroyd NO Infact I would not recommend more than 1bar till you do the fueling. Look at it this way Toyota saw the need to replace the j-spec fueling to run 326bhp on the UK/Euro/US spec supra's...asd you're trying to run 400+ on the j-spec...it doesn't take a genius to work out that it just isn't going to work. But if you feel the need to test it at 1.3 bar, a new engine will cost 5k+ - if you're lucky you can find a decent used one...a fuel system is much much less than that! What's to say the fueling hasn't been done already. The car has an uprated fuel pump and I would guess that the fuel pressure has been raised. If I am correct the work on the car was done at TDI who certainly have a rolling road and I don't doubt a wideband as well. Why are you saying it can't run at 1.2bar, we don't have a definitive spec on the fuel system or the spec of the hybrids...nothing. What I don't understand is why people choose to ask this sort of question on a BBS instead of asking the tuner (or manufacturer) who set the thing up in the first place. Quote Link to comment Share on other sites More sharing options...
Graham Rudd Posted December 15, 2002 Share Posted December 15, 2002 Fuelling has been checked at 1.2 bar and is absolutely fine, probably running a tad rich if anything. I suspect that the Blitz ECU likes to chuck fuel in. What this means in terms of the longevity of the injectors I don't know as they are obviously running at a higher duty cycle than 'normal'. However Gavin is probably correct, probaby best ask TDI any questions you might have, or get it along to a tuner of your choice to give it the once over for 100% peace of mind. Go on sahn! Slap some great big flaming 1000cc injectors on there and get the mother of all turbos fitted! Thats all she's waiting for now! Quote Link to comment Share on other sites More sharing options...
Dragonball Posted December 15, 2002 Share Posted December 15, 2002 Originally posted by GavinL What I don't understand is why people choose to ask this sort of question on a BBS instead of asking the tuner (or manufacturer) who set the thing up in the first place. :confused: Thought that what it was all about m8 - duffers like me asking daft questions from knowledgeable chappies like you instead of asking expensive, unhelpful and disapproving people like Toyota direct! (who wouldn't know anyway!) Paul:thumbs: Quote Link to comment Share on other sites More sharing options...
GavinL Posted December 15, 2002 Share Posted December 15, 2002 Originally posted by Paul E :confused: Thought that what it was all about m8 - duffers like me asking daft questions from knowledgeable chappies like you instead of asking expensive, unhelpful and disapproving people like Toyota direct! (who wouldn't know anyway!) Paul:thumbs: It is and for most of the questions here that is a fair comment. But when good money has been paid to tuning companies or parts suppliers for goods or services, (especially custom stuff such as hybrid/single turbos or fuel systems) surely that must be your first port of call with any questions. By all means double check it on here if you feel the need. I would not change my car without checking with Leon. He knows the car, he set the car up and knows what works and what doesn't. If I turn up the boost or fit a part because a couple of people say it's okay without knowing the full picture and the blows the engine up what do you think my chances of getting a warranty claim through are looking like. Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 16, 2002 Share Posted December 16, 2002 Originally posted by wesmi01 It's fast but after being in ryan's beast I must have as much sensible power as possible!!!!! lol Is that up and running, then? It all went quiet on that front after the ECU 'issue' - is everything ticketty-boo now? What's 1,000bhp like, then...?! -Ian Quote Link to comment Share on other sites More sharing options...
Sharpie Posted December 16, 2002 Share Posted December 16, 2002 Originally posted by Ian C Is that up and running, then? It all went quiet on that front after the ECU 'issue' - is everything ticketty-boo now? What's 1,000bhp like, then...?! -Ian That's what I was thinking Quote Link to comment Share on other sites More sharing options...
