keef701 Posted July 7, 2010 Share Posted July 7, 2010 Hi, I have recently finished installing RLTC, with launch control, and Digi adjuster, to my J Spec TT 6sp BPU spec. The system was previously fitted to a 4 cylinder engine, on a Nissan 180SX, and am wondering if any kind member on here would help me with a good, working DAT file, that I could export to the system? I have two laptops that I can use to communicate with the control unit, one with a USB to serial adapter, the other an old IBM with serial port (but no USB, it really is that old!). So hopefully should be o.k. one way or the other. Can anybody help. Many thanks. Link to comment Share on other sites More sharing options...
Steve Posted July 7, 2010 Share Posted July 7, 2010 Speak to Phil (Terminator) on here. I am sure he will sort one out for you. Link to comment Share on other sites More sharing options...
johnny g Posted July 7, 2010 Share Posted July 7, 2010 If you let me know which channels are allocated to each wheel, I'll send you one Link to comment Share on other sites More sharing options...
keef701 Posted July 7, 2010 Author Share Posted July 7, 2010 If you let me know which channels are allocated to each wheel, I'll send you one I can't remember off the top of my head, the car is at another house at the moment, but I should be able to adjust them in the Racelogic software, as well as putting in my tyre sizes etc. I am looking for good base settings, and then I will be able to configure it to suit my wheels. Any help will be appreciated though. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 9, 2010 Share Posted July 9, 2010 I have used these 2 with good results. One is for 6 speed manual, one for auto, on normal tyre sizes. Use the laptop with the true serial port!racelogic.zip Link to comment Share on other sites More sharing options...
