Oil leak (and help needed)
trinitom
today i was checking my oil level and other stuff as i do every month, and noticed that the oil level was a little under the meddle level on the dipstick.
the car was not smoking at all and never drinked any oil, so i start checking every possible place on the engine.
than i found a leak under the 2nd turbo near to the o2 sensor.
started to remove all the turbo pipes and found the problem on the oil pipe that connects to the turbo, the bolts are tight but it's still leaking.
so i presume a new metal gasket is needed.
just my 2p if someone is having oil leak problems too.
now i had a look on Toyodiy website for part numbers but they are not showing pics, so i don't know what part number is for the metal gasket.
if someone know the part number let me know.
thanks.
