Thinners help guys
Guest blueangel
pretty sure there is mate or they would just sell one for both types (or so i thought).
are you painting yours in 2 pack or cellulose?
EDIT: pretty sure now, cellulose uses thinners and 2 pack uses activator
2k paint use activator and 2k thinner
Cellulose just use thinner
Guest blueangel
cheers guys it was the pearl top coat i was spraying so i just went and bought some standard thinner rather than take the risk.
its normally somehting like 1:1 paint and activator + 10% thinners.
for a top coat antibloom thinners are advised
anti bloom is really for old celly or 1k clear coat application - 2k finishes wouldnt bloom unless you chucked it out in the rain/damp before the paint had cured.
most medium solids 2k direct gloss paints and clears are 2:1 paint/activator ratio
basecoats usually 1:1 or 2:1 with thinner/reducer
high solids paints are often 4:1 or 5:1 but any paints you buy should come with a tech sheet with all the information you need regarding mixing ratios.
also with you pearls an metallics you want to stay away from fast thinner as it can cause blotches/mottling.
Hope that helps
the laquer is 2;1 + 5%
whats a fast thinner
there are 3 normal speeds for thinner, slow,medium (standard) and fast and are used depending on the tempreture and conditions your spraying in.
if it doesnt say on the tin then its probably medium speed.
in very hot tempretures a slow thinner will keep the paint wet longer.
and a fast thinner would be used in colder temps to help the paint flash off faster.
obviusly there is a lot more to it than that but it would be a fairly big write up.:cool:
