FlrSupra Posted July 5, 2010 Share Posted July 5, 2010 Hey. One day my hazard triangle and handbrake-light went on for a second and then went off. Now it has done it few days randomly when I accelerate or brake. I searched for info here that I need to fill up my brake fluid reservoir. Did it today and topped it up to MAX-level.. went for a drive, but no change. Still same lights are coming on randomly. Any ideas what`s next? Link to comment Share on other sites More sharing options...
kjgreen3 Posted July 5, 2010 Share Posted July 5, 2010 Could be handbrake sensor, when you accelerate or brake that sudden change in motion could actuate the sensor, making the handbrake light and hazrad triangle light up. Try disconnecting that sensor and driving for a few days to see if it occurs again. Link to comment Share on other sites More sharing options...
SupraShaun Posted July 5, 2010 Share Posted July 5, 2010 I think this light also comes on if you have the door open while the engine is running, so maybe your door isn't pushing the "sensor thing" in properly. Link to comment Share on other sites More sharing options...
Sted Posted July 5, 2010 Share Posted July 5, 2010 It could be the cat temp' sensor, I had this on my old Supe, I just disconnected it and it was fine. Link to comment Share on other sites More sharing options...
T2 MSW Posted July 5, 2010 Share Posted July 5, 2010 It could be the cat temp' sensor, I had this on my old Supe, I just disconnected it and it was fine. If it was the cat temp sensor that weird looking warning comes up that is meant to be a cat with heat coming off it Link to comment Share on other sites More sharing options...
Sted Posted July 5, 2010 Share Posted July 5, 2010 If it was the cat temp sensor that weird looking warning comes up that is meant to be a cat with heat coming off it This is very true Mike, I forgot that that light came on as well Link to comment Share on other sites More sharing options...
Swampy442 Posted July 5, 2010 Share Posted July 5, 2010 Low brake fluid? Link to comment Share on other sites More sharing options...
Wez Posted July 5, 2010 Share Posted July 5, 2010 Could be handbrake sensor, when you accelerate or brake that sudden change in motion could actuate the sensor, making the handbrake light and hazrad triangle light up. Try disconnecting that sensor and driving for a few days to see if it occurs again. I think this light also comes on if you have the door open while the engine is running, so maybe your door isn't pushing the "sensor thing" in properly. It could be the cat temp' sensor, I had this on my old Supe, I just disconnected it and it was fine. If it was the cat temp sensor that weird looking warning comes up that is meant to be a cat with heat coming off it Link to comment Share on other sites More sharing options...
Wez Posted July 5, 2010 Share Posted July 5, 2010 Low brake fluid? Link to comment Share on other sites More sharing options...
neo2810 Posted July 5, 2010 Share Posted July 5, 2010 I had the same issue recently, and topping up the brake fluid worked...... for a while...... until I discovered one of my calipers was leaking. I assume your brake fluid is staying topped up? If not, get someone to pump the bakes and look for fluid leaking onto one of your rims. Check the connections around the handbrake as well (under the middle panel). Link to comment Share on other sites More sharing options...
Scott Posted July 5, 2010 Share Posted July 5, 2010 Brake fluid sensor? Maybe the connection is broken? Link to comment Share on other sites More sharing options...
kjgreen3 Posted July 5, 2010 Share Posted July 5, 2010 Dont think it could be that as the OP has stated its been topped up, it is worth checking the fluid sensor though as previously stated. The handbrake sensor would also cause the same set of warning lights to actuate, if the sensor return spring has become slack it would cause the same issue. Could someone correct me if I'm wrong and not just roll eyes at me Link to comment Share on other sites More sharing options...
supraturbochris Posted July 6, 2010 Share Posted July 6, 2010 low brake fluid i think matey. Link to comment Share on other sites More sharing options...
Scott Posted July 6, 2010 Share Posted July 6, 2010 I searched for info here that I need to fill up my brake fluid reservoir. Did it today and topped it up to MAX-level.. went for a drive, but no change. Still same lights are coming on randomly. Any ideas what`s next? For those that missed it Link to comment Share on other sites More sharing options...
