Guest klappi Posted July 4, 2010 Share Posted July 4, 2010 Hello can someone show me how can i parallel my twins in my supra. Quote Link to comment Share on other sites More sharing options...
Scott Posted July 4, 2010 Share Posted July 4, 2010 Permenant or just for a trial? Quote Link to comment Share on other sites More sharing options...
Thorin Posted July 4, 2010 Share Posted July 4, 2010 http://www.internetwork.org.uk/mechanical/ttc/ttc.htm Quote Link to comment Share on other sites More sharing options...
Guest klappi Posted July 4, 2010 Share Posted July 4, 2010 Oh i think like permanent or isn´t it ok,should i need anything to do it? Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted July 4, 2010 Share Posted July 4, 2010 It's a German Video Tutorial. Done it works perfekt Quote Link to comment Share on other sites More sharing options...
kill1308 Posted July 4, 2010 Share Posted July 4, 2010 From what I've read, I don't think it's wise running it long term without an aftermarket ECU allowing it to be mapped correctly for the different characteristics of the True Twin setup. I think it's used as a means of troubleshooting different components of the sequential setup. I remember reading something about a potential lean spot at 3.5-4k. Don't take my word for it though, I'm sure someone who knows what they are talking about will be along soon to set you on the right track Quote Link to comment Share on other sites More sharing options...
Scott Posted July 4, 2010 Share Posted July 4, 2010 If you want to do it properly you will need to wire the actuators in place. Swapping the vac lines over is only really a temporary solution. You don't want the actuators constantly pressurised. Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted July 4, 2010 Share Posted July 4, 2010 Yes forgot to add that. But it's a good way of testing it if you like it. Quote Link to comment Share on other sites More sharing options...
Guest klappi Posted July 5, 2010 Share Posted July 5, 2010 Jo cool thank you Aleks i will test it if my twins will work. Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted July 5, 2010 Share Posted July 5, 2010 Got Problems with the Turbos? Quote Link to comment Share on other sites More sharing options...
brettjones Posted July 5, 2010 Share Posted July 5, 2010 If you want to do it properly you will need to wire the actuators in place. Swapping the vac lines over is only really a temporary solution. You don't want the actuators constantly pressurised. what damage can/or will it cause if you dont wire them in place ? Quote Link to comment Share on other sites More sharing options...
Guest klappi Posted July 5, 2010 Share Posted July 5, 2010 'Oh no problems with the turbos i think it went fast forward. :-) Quote Link to comment Share on other sites More sharing options...
