JACDAV Posted July 4, 2010 Share Posted July 4, 2010 Hi. The other day I was showing of for some friends with a lilttle wheel spin, when I stopped I stepped on the clutch but there were no reaction and I had to kill the engine to put it into neutral?? I waited a while to cool the clutch ( RPS street max ) but with no success. When I drove home I had to start the car into a gear otherwise I could not shift, when I had driven a couple of km´s with the clutch down and accelerating up and down the clutch slipped it´s grip. Any ideas?? Is it the center bearing in the crankshaft?? Please help, I am a lilttle bit worried to drive the car, mabee the clutch or the tranny suddenly will explode with catastropy consequenses Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted July 4, 2010 Share Posted July 4, 2010 Slave cylinder has failed by the sound of it. I suggest you don't drive the car until you sort it. Quote Link to comment Share on other sites More sharing options...
JACDAV Posted July 4, 2010 Author Share Posted July 4, 2010 Thanks.. also my first thought, but the clutch felt as hard as it used to bee?? Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted July 4, 2010 Share Posted July 4, 2010 i miss read at first when i saw tranny lol Quote Link to comment Share on other sites More sharing options...
JACDAV Posted July 4, 2010 Author Share Posted July 4, 2010 :-) Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 4, 2010 Share Posted July 4, 2010 Maybe you heat welded the clutch to the flywheel? I think that can happen under some circumstances or I might have dreamt it Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 5, 2010 Share Posted July 5, 2010 You have probably fused the sintered plate material to the flywheel and cover, Powerhouse Racing have something on this, if indeed this particular clutch of yours is sintered? I have had so much trouble with RPS clutches (ripping a new one out today that has serious issues) I have to say that I would never supply and fit, as I would be worried that it would be coming out again at my cost If it's not sintered the driven plate may have warped with the heat and now won't release fully. Quote Link to comment Share on other sites More sharing options...
JACDAV Posted July 5, 2010 Author Share Posted July 5, 2010 Thanks... It is a sintered clutch. I have driven it since the trouble occur and have no problems since. The clutch is working as it use to. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 5, 2010 Share Posted July 5, 2010 They do not like, nor are they designed to take many tyre smoking starts. The only truly relaible drag race clutches that also work well on the road are proper carbon / carbon ones from the likes of AP and Tilton. Sintered plates will not stand the heat of multiple slips, and as you have found, will fuse together. Quote Link to comment Share on other sites More sharing options...
Terminator Posted July 5, 2010 Share Posted July 5, 2010 I have had so much trouble with RPS clutches (ripping a new one out today that has serious issues) I have to say that I would never supply and fit, as I would be worried that it would be coming out again at my cost Another clutch to avoid added to the list. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 5, 2010 Share Posted July 5, 2010 In fairness some people seem to have no trouble, but at least if the customer supplies it and I just fit *HE* eats the labour cost if the clutch goes faulty Quote Link to comment Share on other sites More sharing options...
Terminator Posted July 5, 2010 Share Posted July 5, 2010 I guess as for most parts, life expectancy is down to how the part is used. Quote Link to comment Share on other sites More sharing options...
