Guest Gcampbell0612 Posted July 3, 2010 Share Posted July 3, 2010 Help, well here goes ,ill try to explain my problem,my supra na 1995,was running perfect the other day then i washed the car and quickly over the engine bay,when i went to start the car around 3 hours later it was running i think on 5 cylinders ,when you push the throttle down there was lack of power and still the scooby noise,i let the car sit a couple days and still the same but not as worse if you put the throttle down to say a quarter the way down when on the move it seems to run on five cylinders until the throttle catches up then its fine but also a smell of fuel in the car until you push the throttle down again,when idiling it sounds like its running on five cylinders,have i got water in somwhere i shouldnt or have i a sticky injector,hope this makes sense to someone thanks Quote Link to comment Share on other sites More sharing options...
pezzler Posted July 3, 2010 Share Posted July 3, 2010 (edited) N/A's are notorious for this problem. I had it with my old car, it would seem that you have got a bit of wet water down on your spark plugs. Try to get in there and mop it up, then take the plugs out one by one and give em a clean up/dry off. Good luck, the spark plugs are a PITA to get to on a N/A Edited July 3, 2010 by pezzler (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Gcampbell0612 Posted July 3, 2010 Share Posted July 3, 2010 excellent ill go and try that thankyou so much for the quick reply Quote Link to comment Share on other sites More sharing options...
Guigsy Posted July 3, 2010 Share Posted July 3, 2010 N/A's are notorious for this problem. I had it with my old car, itg would seem that you have got a bit of wet water down on your spark plugs. Try to get in there and mop it up, then take the plkugs out one by one and give em a clean up/dry off. Good luck, the spark plugs are a PITA to get to on a N/A i hate that wet water. I always use the dry kind when im washing my car now. Quote Link to comment Share on other sites More sharing options...
pezzler Posted July 3, 2010 Share Posted July 3, 2010 I always use the dry kind A wise move my friend Quote Link to comment Share on other sites More sharing options...
Porky1978 Posted July 3, 2010 Share Posted July 3, 2010 i hate that wet water. I always use the dry kind when im washing my car now. Quote Link to comment Share on other sites More sharing options...
Guest Gcampbell0612 Posted July 3, 2010 Share Posted July 3, 2010 Ok i removed the 4 easy spark plugs gave everything a clean ,put it back together and hey presto sounds and moves like a supra should again, many thanks for the help Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 3, 2010 Share Posted July 3, 2010 Are there 2 difficult spark plugs?? And congrats on the fix Quote Link to comment Share on other sites More sharing options...
Homer Posted July 3, 2010 Share Posted July 3, 2010 On an NA, yes The ones under the intake manifold Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 3, 2010 Share Posted July 3, 2010 Neck wound in lol Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 3, 2010 Share Posted July 3, 2010 On an NA, yes The ones under the intake manifold hahahaha, this is one of those threads where I sit and chuckle.... not because of the newbie mistake but because I've done it twice Airline is the easiest way to get the water out Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted July 3, 2010 Share Posted July 3, 2010 good u sorted the problem mate Quote Link to comment Share on other sites More sharing options...
Blackie Posted July 3, 2010 Share Posted July 3, 2010 but because I've done it twice Twice?? Ive done it once but managed to fill the plug recesses up so they were like little wells Quote Link to comment Share on other sites More sharing options...
