lower front arms also what diff oil you 2way guys recommend?
jme
right guys im doing a little clean up and replacement of anything that is pooped under the front and rear arches. so far iv changed the drop links, track-rod ends and the rear trialling arms. O and dropped the diff oil out as its a foot in the air along with the gear box oil and all the other servicesy bits.
when i was checking over the bushes i found that the front lower arm had a lot of space both sides of the bush (Pic) is this right??? also as i said in the title what diff oil would you recommend.
