2 second missfire on kickdown, What is it?
Blackie
I had a service on the N/a auto a few days ago, Gear oil, Engine oil and filter and plugs were changed. It turns out i had the wrong plugs with the wrong gaps in for the past year or so, Now the proper ones have been fitted when i boot it (To get the kick down)
It misses three beats and then picks up, Its a missfire for deffinate. It was worse in the rain but it still continues in hot weather. I put some esso petrol in last night, never used it before, This couldent be anything to do with anything could it or am i just grabbing at straws?
not sure it is this but double check the hose which runs behind the engine, as mine had a tiny pin hole recently and when running a slight spray of water was getting into the plug channels causing it to short.
but if its just missing on kickdown it could be a faulty plug and its only causing a problem under load.
The weird thing is i just ran it right down with the esso petrol put my normal stuff in and after it got through to the engine its not missing at all. Is that even possible?
Resetting the ECU may help, especially if you're using a lower RON fuel.
Ahh just saw this, so it could be the esso petrol? lower ron than my normal stuff? Also, How would you reset the ECU?
Edited by Blackie (see edit history)
Also, the little white clip that holds the leads apart is missing so the plug leads are touching, Could this be anything?
I've never heard anything about cross firing in the time i've been on here (although I've never paid much attention to NA threads in tech :D )
PM sent :)
I have had a missfire underload on my n/a. I have just checked my newly fitted plugs part number and the whole internet says they are for a mk3 Supra not a mk4, The code on the ones i have fitted is BCPR6EY, A tech item from this site says they should be BKR5ES-11, Is this likly to be the problem? Its only the plugs that were changed and now i have this missfire?
Some info about the plugs you have:
BCPR: Correct code for copper plugs on the supra
6: A little too cold for the NA, this is what the TT normally uses. I think a 5 is normal for an NA
E: Correct thread pitch for the supra
Y: means it's V-grooved
So the issue might be that the plugs are just too cold a rating for the NA (which could cause a misfire)
The Spark plug guide seems to miss copper plugs for the NA, not sure why as most NA's use them. The code for the coppers is BCPR5ES and gap them to 1.1mm
