ECU pin out info
David P
I've been through the AT section twice and can't find any reference to a difference in the spec. It's likely to be stronger in the TT, but doesn't necessarily mean the stall is any different. It does state that the base stall on both the NA and TT is 2000:1 so again indicates no difference. HTH.
Edit - the manuals only split when there are differences, when specs and assembly in any particular section are the same it gets bundled.
Cheers for that, I can leave that setting alone and move on.
At the mo, the Suprastick is connected to the no. 1 speed sensor. (16 blips per wheel rev)
I have installed an ABS sensor, (48 blips per wheel rev) so tomorrow will check it functions, wire that in and polish up the configurations.
