Grinding noise (possibly the transmission)
Attero
I took my Supe into the local Toyota garage the other day to check up on what this grinding metal noise (sort of like a rusty metal grinding or a tomb door opening noise) coming from the front. It happens at low revs sometimes randomly but I couldn't quite figure out when it was causing it. The guy at the garage gave it a little run and he managed to make the noise sound pretty loudly by fiddling around with the clutch and accelerator.
He said it's probably the transmission and so I'm going to get it taken in to check up on it.
Anyone have any ideas what it could be and if it's something I should start worrying about? :rolleyes:
Also getting the crank pulley checked. ;)
