mrboost Posted December 13, 2002 Share Posted December 13, 2002 How easy are these to fit? Anyone here done it on the Auto ? Boost Quote Link to comment Share on other sites More sharing options...
GavinL Posted December 13, 2002 Share Posted December 13, 2002 Originally posted by mrboost How easy are these to fit? Anyone here done it on the Auto ? Boost I don't know the answer on the fitting but why the HKS Kit . You can cheaper coolers that will do the same job, Serab are very popular in the US Quote Link to comment Share on other sites More sharing options...
mrboost Posted December 13, 2002 Author Share Posted December 13, 2002 cheaper than £80 ? boost Quote Link to comment Share on other sites More sharing options...
GavinL Posted December 13, 2002 Share Posted December 13, 2002 Originally posted by mrboost cheaper than £80 ? boost £80...I think they charge £600 for an oil cooler which I understand to be the same thing basically. Always willing to learn, do you have a piccy or link to follow? Thanks Quote Link to comment Share on other sites More sharing options...
adi Posted December 13, 2002 Share Posted December 13, 2002 A transmission oil cooler? Even mocal ones are available from £30+, although one for the supra would probably be around £80. Im fitting an 'unbranded' version soon for my auto...hopefully without losing any fluid in the process as i've got £130 worth of new stuff in the gearbox. I think the size i've got will just do the job. As far as i can tell, its a process of clamping the lines, extending the piping, mounting the cooler somewhere in the front of the car and plumbing it all up. At least i hope its that easy. Quote Link to comment Share on other sites More sharing options...
dude Posted December 14, 2002 Share Posted December 14, 2002 Im putting 2 0n, one each side , its real easy like you said just clamp the lines extend the hose and off you go , there is no pressure to speak of so leaks wont be a prob. if you use good hose and clips . John:sex: Quote Link to comment Share on other sites More sharing options...
adi Posted December 14, 2002 Share Posted December 14, 2002 The one i'm fitting is 200x120x30, 10 row.. anyone know if it'll be up to the job? Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted December 14, 2002 Share Posted December 14, 2002 Originally posted by dudersvr Im putting 2 0n, one each side , its real easy like you said just clamp the lines extend the hose and off you go , there is no pressure to speak of so leaks wont be a prob. if you use good hose and clips . John:sex: john what sort of prices are they and any links of where to buy from? i have not long had a gearbox oil change too.its always better to run cool. if you futting 2 coolers where would be best to place them and do you need to fit some sort of temp gauge or is that overkill thanks Quote Link to comment Share on other sites More sharing options...
dude Posted December 15, 2002 Share Posted December 15, 2002 Mark Will let you know when ive found a couple of decent coolers i expect them to be cheap , ive got an aftermarket nosecone coming from paul E im going to fit one in each vent at the side cause ive got a FMIC going in the middle so when you look at the front of the car each opening has a cooler in it , i would say a temp guage is overkill unless you are running a hi-stall converter and line lock in which case it is a must , i will prob change to syn. fluid cause it handles heat a lot better and doesnt break down , keep an eye out for my progress reports when you see a pic of the car with the coolers fitted jog my memory and i will post costs etc . John Quote Link to comment Share on other sites More sharing options...
