Sub-throttle position motor
pezzler
Hi all,
I have recently been sorting a few niggles; one of which being jerky gear changes (its an auto)
I had the throttle body off today as I wanted to check the throttle sensors and sub-throttle motor
I tested the motor using Toyota guidelines (check resitance between pins: A and A-. Pins: B and B-). I had readings of 0 ohms in both instances
So it looks like i'm replacing the motor. Does anyone know if its just a "plug and play" part? I'm assuming that it wont need to be calibated, and the sub-throttle position sensor will let the ECU know when to give the motor some juice. Is this correct?
Thanks
