Carl Posted June 30, 2010 Share Posted June 30, 2010 This is a long shot but I need to remove the bottom pulley to remove the cambelt etc. does anyone living near Gloucestershire happen to have a puller that will remove it. cheers Carl Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 30, 2010 Share Posted June 30, 2010 sat in same boat. you wouldnt have a crank locking tool would you? how did you get your bolt out? Link to comment Share on other sites More sharing options...
Carl Posted June 30, 2010 Author Share Posted June 30, 2010 sat in same boat. you wouldnt have a crank locking tool would you? how did you get your bolt out? Lol, I havn't. I need that to. Judging by the response looks like I'll have to buy the tools. Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 30, 2010 Share Posted June 30, 2010 any idea where they can be baught? i cant see me finding any. i hate seeing my car incomplete Link to comment Share on other sites More sharing options...
Swampy442 Posted June 30, 2010 Share Posted June 30, 2010 Ive dont it twice on 2 different cars and only used an air wrench and a generic 3 leg puller from Machine Mart. Sods law is next time I attempt it its gonna be a total bitch! Link to comment Share on other sites More sharing options...
dangerous brain Posted June 30, 2010 Share Posted June 30, 2010 Well I've only ever used a breaker bar and the starter motor and made a quick puller to whip the pulley off with no other components removed. Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 1, 2010 Share Posted July 1, 2010 thats how i normanlly do it , bit this particular one is seriously tight. the starter motor or my inch drive gun didnt even touch it. Link to comment Share on other sites More sharing options...
SBDJ Posted July 1, 2010 Share Posted July 1, 2010 Having just sworn at mine, I used the starter motor to whip the bolt off, then I used one of these pullers + shock to remove my pulley: http://www.sears.com/shc/s/p_10153_12605_00947626000P Making your own is simple enough if you can't find one. I had major problems in that the threaded bolt holes on my pulley wouldn't hold but hopefully you won't have that issue! Link to comment Share on other sites More sharing options...
Shane Posted July 2, 2010 Share Posted July 2, 2010 any idea where they can be baught? i cant see me finding any. i hate seeing my car incomplete Craig, just knock one up, if you want I will take a photo of mine and send it to you. Its so easy to make a basic tool and I have used mine several times on 3 supras now. It's made from two peices of angle iron cut from an old bedframe believe it or not. One piece is about 50cm or so long and the other I guess 30cms. Bolted together to make a Y form (bolted at the join not even welded) that sits flush to the pulley. A hole drilled in each part that allows you to bolt it to the threaded holes either side of the bolt. Your socket then just fits inside the V. Then in use the long part of the tool rests against the chassis on the driver side. Honest mate, once you do it you will wonder what the fuss was all about. Link to comment Share on other sites More sharing options...
