Pads and Disks front/back problem
Guest brko
Hi
I want to change my front and back pads and discs, but I don't know which to get because for pads they are asking for the disk dim. and is it 2 or4 callipers at the front.
I have a m reg n/a supra and it's on 17inch wheels.
Also where can I get cheap discs and which pads do I get???
Thanks a lot guys
Guest Supra-T
If it has the standard import brakes then it's 2 pot fronts and 1 pot rears, if it's had the UK brakes fitted then it's got 4 pot fronts and 2 pot rears.
Btw mate, if you do a search you will find a lot of this info already covered. :)
Guest brko
Still stuck at work will do it asap
Also can somebody give me links to cheap but good brake disks for front and back
Cheers
Guest brko
I went to Toyota and they told me that front and back are around £90+ each so around less then £400 .
There must be some good quality but a bit cheaper???
I would say no mate, toyota designed these disks and pads for a reason and spent millions on R&D.
Id use OEM ones, or if you can save and buy UK spec Calipers, disks, pads if you can, other than that. go with OEM ones.
I'm not sure how many times you're going to ask "are there better and cheaper ones" in the face of people saying "no, buy OEM" - are you in management at work? :D
If you buy crap off ebay, you aren't allowed to come back here and bitch about them lasting 2000 miles and warping/cracking.
