TTRickeh Posted June 29, 2010 Share Posted June 29, 2010 I'm taking my interior half to bits as i'm trying to route all the wires for my 'ICE' install. I've taken all the screws off the centre armrest (the ones at the front, I assume there aren't more) and managed to seperate the armrest/gear housing from the dash but it still feels like it's attached to something at the rear. Should I just pull? Link to comment Share on other sites More sharing options...
Attero Posted June 29, 2010 Share Posted June 29, 2010 I will probably be doing the same thing at some point so I'd be interested in this too. Was it easy to detach the center arm rest, or did you have to detach anything else to get the center armrest off (such as the bottom dashboard - shift stick panel)? Link to comment Share on other sites More sharing options...
TTRickeh Posted June 29, 2010 Author Share Posted June 29, 2010 I will probably be doing the same thing at some point so I'd be interested in this too. Was it easy to detach the center arm rest, or did you have to detach anything else to get the center armrest off (such as the bottom dashboard - shift stick panel)? Well I don't know yet because i'm asking how to remove it, lol. You will need to remove the gear stick panel because underneath it are some screws which need to be removed. Link to comment Share on other sites More sharing options...
dwayne Posted June 29, 2010 Share Posted June 29, 2010 there are screws in the armrest compartment too as far as i remember Link to comment Share on other sites More sharing options...
JustGav Posted June 29, 2010 Share Posted June 29, 2010 there are screws in the armrest compartment too as far as i remember Yup, two small ones RIGHT at the back Link to comment Share on other sites More sharing options...
supra steveo Posted June 29, 2010 Share Posted June 29, 2010 5 screws in total for this 2 in the arm rest, 1 under the gear surround panel and 2 at the front Link to comment Share on other sites More sharing options...
Scott Posted June 29, 2010 Share Posted June 29, 2010 You don't need to take it off bud. You can just remove the screws along the side you want to put the wires in and tuck them up and over. Works a treat. I even got some wires into the centre box without removing it lol. Link to comment Share on other sites More sharing options...
TTRickeh Posted June 29, 2010 Author Share Posted June 29, 2010 Ah there they are! I had so many screws stored in the armrest already I didn't see them Cheers guys. Link to comment Share on other sites More sharing options...
TTRickeh Posted June 29, 2010 Author Share Posted June 29, 2010 You don't need to take it off bud. You can just remove the screws along the side you want to put the wires in and tuck them up and over. Works a treat. I even got some wires into the centre box without removing it lol. I'd gotten so far that it would've damaged my pride had I not managed to take it off Link to comment Share on other sites More sharing options...
