Coolant boiling and car being overwarmed
weskereric
At the begining, coolant was just boiling in the expansion bottle when we stop the engine and the temperature gauge didn't move.
But now, the coolant is also boiling driving and the car is
being overwarmed.
All water has evaporated.
We already change the rad cap without sucess.
There is no exhaust smoke, coolant and oil are clear, and there is no coolant leak
What could it be ? :search:
Is the coolant circulating? Starting from cold with rad cap off check the fluid is circulating when you rev the engine.
Check hoses are tight and there are no leaks and as already said make sure there are no air locks in the system.
Check the new rad cap you have fitted is sealing properly, make sure the top of the rad where the cap seals against is clean and free of any crud/rust.
Check thermostat isn't stuck.
If you do all that and it's still overheating then try replacing the rad.
The only thing putting me off the thermostat is the fact that the coolant is boiling into the overflow. Would that not suggest that the water was in fact flowing through the rad rather than just sitting in the block?
Soaring temps with a fairly cool rad would suggest thermostat to me right away.
