Rinus Posted June 27, 2010 Share Posted June 27, 2010 What is best for GT4082 setup with stock rail and walbro? 63507 (6 X 850cc) TOYOTA SUPRA (JZA80 2JZ-GTE, JZA70 1JZ-GTE) SOARER (JZZ30 1JZ-GTE 96.8-) MARK II (JZX81/90 1JZ-GTE) 850cc - Side, High Impedance, 1 Hole, Red Brown (Pic 22) Time 0.85 msec (Collars Needed Part No 63525) 63564 (6 X 800cc) TOYOTA SUPRA (JZA80 2JZ-GTE, JZA70 1JZ-GTE) SOARER (JZZ30 1JZ-GTE 96.8-) MARK II (JZX81/90 1JZ-GTE) 800cc - Side, High Impedance, 2 Hole, Brown (Pic 17) Time 1.6 msec For the 850cc's I need collars? Don't think I need them on the 800cc... And the lag time is 0,85 vs 1,6 msec, is lag time important? And 1hole vs 2hole injector, also important? Will run it with vipec88 standalone ecu, anyone experience with this? Link to comment Share on other sites More sharing options...
Ricky49 Posted June 27, 2010 Share Posted June 27, 2010 I went for the 800cc Link to comment Share on other sites More sharing options...
Rinus Posted June 27, 2010 Author Share Posted June 27, 2010 I see many people go for the 800cc's, I will be probably too... But like to know about these little differences... Link to comment Share on other sites More sharing options...
Ryan.G Posted June 27, 2010 Share Posted June 27, 2010 The 850cc need collars and these can sometimes not seal 100% if the collars are machined poorly with i have seen alot. Go for the 800cc Link to comment Share on other sites More sharing options...
Jamesy Posted June 27, 2010 Share Posted June 27, 2010 yep - 800's mate Link to comment Share on other sites More sharing options...
Rinus Posted June 28, 2010 Author Share Posted June 28, 2010 Ok 800cc's, AMEN:) Link to comment Share on other sites More sharing options...
mark newman Posted June 28, 2010 Share Posted June 28, 2010 850 for me Link to comment Share on other sites More sharing options...
MartinBattye Posted June 29, 2010 Share Posted June 29, 2010 remember to make sure you set your injector settings in the Vipecv88 for peak and hold Link to comment Share on other sites More sharing options...
Rinus Posted June 29, 2010 Author Share Posted June 29, 2010 Ok thanks for the tip... Link to comment Share on other sites More sharing options...
