Chris Wilson Posted June 3, 2005 Share Posted June 3, 2005 On my Skyline GTS-t (2WD), but shows what I do here: Dry build of my home made front brakes, need to do hoses and find some 12mm cap heads now.... Rear brackets and bells away being anodized, will send pics when done! Pics here Quote Link to comment Share on other sites More sharing options...
Alex Posted June 3, 2005 Share Posted June 3, 2005 Very nice...should be more than enough for a light weight GTS-t...355mm? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 3, 2005 Share Posted June 3, 2005 Have those calipers got dust seals Chris?? Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 3, 2005 Share Posted June 3, 2005 Love those marker-pen arrows -Ian Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 3, 2005 Author Share Posted June 3, 2005 No dust seals, they are race calipers. Off a Porsche 962 Le Mans Group C car, just to add a bit of class The rear calipers are off an Aston Martin DB9 or something. Just what we had lying around doing nowt, with small pistons and radial mount. 356 mm x 32 mm thick, CP3581 AP discs I don't thick the arrows will last long.... Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 3, 2005 Share Posted June 3, 2005 No dust seals, they are race calipers. Off a Porsche 962 Le Mans Group C car, just to add a bit of class The rear calipers are off an Aston Martin DB9 or something. Just what we had lying around doing nowt, with small pistons and radial mount. 356 mm x 32 mm thick, CP3581 AP discs I don't thick the arrows will last long.... Thought so, regular rebuilds then? What are you doing with the rears to keep the balance, bias adjuster? Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 3, 2005 Share Posted June 3, 2005 Custom built balancer valves I suspect, I recall you doing a trick setup like that for the RX? -Ian Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 5, 2005 Author Share Posted June 5, 2005 Initially using an AP balance valve, may remove servo and convert to dual mater cylinder depending on pedal effort needed when testing. If the brakes are put away hot the lack of seals doesn't really affect things much, but it's a track car anyway, and will get little use on the road, except driving to tracks, and with luck, back again. It's now piped up with proper P clips on the hoses et cetera, and bled. Back brakes next week, as soon as stuff gets back from the platers. Fitted some 01 compound Performance Friction carbon metallic pads in endurance thickness and piped the calipers yesterday afternoon, so the fronts are now finished.Pics Here Quote Link to comment Share on other sites More sharing options...
Pete Posted June 5, 2005 Share Posted June 5, 2005 Well if they don't stop you quick before entering a corner I don't know what will! Nice looking kit. Shame they don't stay that shiney isn't it? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 5, 2005 Author Share Posted June 5, 2005 They should do the job, especially as the 2wd Skyline is hugely lighter than the 4wd trucks. It's like race engine internal parts, sometimes it seems a shame to fit them into the depths on an engine, they look much nicer sat on the bench Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted June 5, 2005 Share Posted June 5, 2005 Are you going to be using slicks? Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted June 5, 2005 Share Posted June 5, 2005 what sort of weight is gtr against the weight of your track car and have your stripped interior nice brakes Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 5, 2005 Author Share Posted June 5, 2005 No slicks, Michelin Pilot Sport Cups. Monkey. Dunno without looking it up. When i get around to doing the geo, (a lot of parts to make first), I'll have the weights. Can't decide whether to gut it or not. If I do it will have a weld in cage in it. If i don't it will be road comfortable, but floppy.... Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted June 6, 2005 Share Posted June 6, 2005 No slicks, Michelin Pilot Sport Cups. Keeping it road legal then? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 6, 2005 Author Share Posted June 6, 2005 Yes, definitely road legal, I want to have something i can drive to Oulton or Donington and just get in and go around for a few hours fun. Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted June 6, 2005 Share Posted June 6, 2005 Have you still got that Super Sports or whatever it was? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 6, 2005 Author Share Posted June 6, 2005 Yep, just going to put some new tyres on it for Oulton on Wednesday, I rebuilt engine and box over the winter and it's now run in and shaken down. Pics from the last Oulton at ftp://ftp.chriswilson.tv/home/zeus Quote Link to comment Share on other sites More sharing options...
