Photoshop help please?
aman00123
Quite strange but going by my current wheels and test fitting the overfenders it looks as if they'll be flush at the front and 13mm out on the rear. If this is correct do you think the 13mm is forgiveable?
If not the cost of a set of wheels to fit properly will be pretty much double the cost of these plus the rear tyres :(
It doesn't on mine either just my current wheels sit inside the arch, the overfender doesn't increase the size, i.e. I could put the RH's on without the overfender and they would sit flush
You are right though it is all if's and but's and I think I should now shut up and either take the plunge or save up and get some ones that I know fit
