Welding for beginners
monsween
Can anyone recommend me a welding setup.
Looking to do odd bits and bobs and get learning. Ideally one that i can use for car repairs in the future (project cars not the supra :p)
So basically one that'll last me a while and ideal for my skills/work
If you can point it out on Machinemart i may be able to get it :)
Im not sure what im after, MIG, TIG, ARC etc
http://www.machinemart.co.uk/shop/product/details/151te-turbo-mig-welder/path/diy-mig-welders
this was the first welder i bought new and is still going strong after hundreds of hours work,if you have the money then i would recomend the kempi 180 minarc mig which is what i use now.
i wouldnt get too small a machine as the rating isnt up to much.
I'm looking to get one that'll last me 10-20 years type thing so dont want to buy 2 cheap ones if you know what i mean
the 151 has been going for about 10 years now.and has done a lot of welding,example 2x2 box section gates were made over 7 years ago for a dairy and they are still strong now.
if not then the kempi is about £750 and is a cracking little machine
linner? Sorry i'm very new to this and going to start reading up once i get it
the welding wire feeds up through the liner,this is plastic so best change it to a metal one as soon as you get it,they are only a fiew pounds and easy to change.the problem with the plastic one is the wire can pierce it if theres a kink ect then its a pain in the ass.
not much point in reading up best to trial and error.Get some thickish metal to start with the practice and slowly use thinner metal.You will get used to the machine without getting stressed blowing hole in the metal.
  • 2 weeks later...
