Blitz ecu ????
Bailey.
I doubt you will be able to find any detailed answers, the Blitz ECU is a very old product and was probably fitted early in the car's life.
I'd guess it'll be similar to the likes of the Mines and TOMS ECU's and have modified fuel and timing mapping, it'll probably also remove the standard fuel cut and may also remove the speed cut.
I would doubt it's had a remap, the in-house ecu's normally just have boost cut and speed limit removed, as mentioned the Toms one also makes some small timing changes.
It will have been on the car a very long time so I'm sure you can consider it safe, but no harm in getting it dyno'd. Do you have an AFR gauge installed?
You'll need a wideband O2 sensor (which will come in the afr gauge kit), they are normally mounted in a flange near the front of the 2nd decat. If you don't have a flange in the pipe one will need to be welded in.
