help!!
djg99
Ok need some help here, was having a look to find the loud rattle at the front of the car ive taken the cover off the engine and taken the plugs out to do a Compression test, the front 2 i'm getting 150 psi middle two around 120 and the other 2 140 psi, also the three at the back are dripping in oil!!! what sort of pressure should i be getting??? now when turning it over no loud noise, also lots of oil at rear of engine but cant see where its coming from. any ideas??? had a search on site but cant find it!!! car is a TT auto. cheers
could that be causing a knocking noise, where the pistions are hitting the valves. also the belt has a little give, is that how it could it jump a tooth?? Think im guna have to phone the garage in the morning!! only thought id look meself as garage is realy busy!
Edited by djg99 (see edit history)
The 2JZ with stock cams is non-interference so that shouldn't be a concern.
