PC based oscilloscopes, is this a decent one?
Chris Wilson
I have a couple of "normal" oscilloscopes for automotive use, but I am always fearful of taking them racing as they are delicate and need the generator or a converter running to power them up. I was going to buy a Picoscope software and hardware package, which is geared to automotive usage, but they seem very costly, and as far as I can tell you gain only the software specialisation that will "set up" the scope for rading say O2 sensor outputs, rather than doing it manually.
I saw a Dataman PC based scope on Ebay and set what I thought was a reasonable bid, and have just found I have won it. It is a bit late to ask, but what do any of you electronic experts think of the spec, which is linked to via the ad itself? I will probably only use it on automotive stuff, so the 150 Mhz is a bit OTT, but otherwise??
I am more in need of a better laptop than ever now, as I am unsure if mine has USB2 ports, I fear they are USB1. How do I tell? Can I get a PCMCIA card or whatever they are called to update it in the short term, to USB2?
Thanks.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160447513887&autorefresh=true
Ian C has a Pico-something that I talked him into buying when we were trying to diagnose something on his car. As far as I know he's never used it.
I know it only has 0-5V inputs but I made up a simple interface card to convert them to 0-12v.
