rxv8 Posted June 23, 2010 Share Posted June 23, 2010 (edited) ................................ Edited June 30, 2010 by rxv8 (see edit history) Quote Link to comment Share on other sites More sharing options...
marcAB10 Posted June 24, 2010 Share Posted June 24, 2010 Erm.... Pics? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted June 24, 2010 Share Posted June 24, 2010 Sounds like a nice car. If it's not already de-carted then that's the next think you want to do. As for an intercooler, you could go front mount, but Whifbitz do upgraded side mount intercoolers which will cope with BPU, and that's what I'd go with. You'll also want a boost controller at some point. Also, if it's running J spec brakes I'd want to upgrade before going BPU. Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 24, 2010 Share Posted June 24, 2010 (edited) And a restrictor ring if you decat it so the boost doesn't go running off, if its a j spec. Differant grade plugs and if its been sat around for a while before doing any upgrades i'd be checking the the brakes, the brake lines, changing all the fluids, engine, g box, diff, brake, coolant and basicly give it a good look over all the mechanical bits, the paintwork should be the last thing to do Edited June 25, 2010 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
rxv8 Posted June 24, 2010 Author Share Posted June 24, 2010 And a restrictor ring if you decat it so the boost doesn't go running off, if its a j spec. Differant grade plugs and if its been sat around for a while before you doing any upgrades i'd be checking the the brakes, the brake lines, changing all the fluids, engine, g box, diff, brake, coolant and basicly give it a good look over all the mechanical bits, the paintwork should be the last thing to do ye will be doing that anyway...cheers... Quote Link to comment Share on other sites More sharing options...
rxv8 Posted June 25, 2010 Author Share Posted June 25, 2010 (edited) .................. Edited June 30, 2010 by rxv8 (see edit history) Quote Link to comment Share on other sites More sharing options...
rxv8 Posted June 25, 2010 Author Share Posted June 25, 2010 Erm.... Pics? pics above... Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted June 25, 2010 Share Posted June 25, 2010 Should be a nice project for you to return this car to some former glory Quote Link to comment Share on other sites More sharing options...
scotty71 Posted June 25, 2010 Share Posted June 25, 2010 Should be a nice project for you to return this car to some former glory will be a good project as Bobbeh said... you just going to waft over that front bumper with some primer and 022 paint Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 26, 2010 Share Posted June 26, 2010 The mines ECU is a bit if an unknown. It's not remappable, its basically a stock ecu that's ben fettled. Mines ECU's don't need a fuel cut defender, and do some trickery with the timing IIRC. Quote Link to comment Share on other sites More sharing options...
rxv8 Posted June 26, 2010 Author Share Posted June 26, 2010 i hope to be mot d again on tues,have new wheels,ab flug bonnet...just need a bumper although its repairable i think it will one seriously heavy bumper if it was...lol... was told by the previous owner it boosted to about 1.1 bar... Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 26, 2010 Share Posted June 26, 2010 Re Mines ECU's theyre mapped to a customers specs, you used to be able to find out exactly what had been done by mailing Mines with the serial number but I think theyve stopped doing that. I had a Mines before and its a bit more than a breathed on stock ECU, it had an extra circuit board on top. But expect timing changes, boost and rev limit increases. Quote Link to comment Share on other sites More sharing options...
DARETT Posted June 26, 2010 Share Posted June 26, 2010 That will look very nice once your done with it Nige, a right Bargain!! Quote Link to comment Share on other sites More sharing options...
rxv8 Posted June 29, 2010 Author Share Posted June 29, 2010 (edited) ............. Edited June 30, 2010 by rxv8 (see edit history) Quote Link to comment Share on other sites More sharing options...
DARETT Posted June 29, 2010 Share Posted June 29, 2010 Looking good, change the front indicators to clear one's and whack on that Abflug bonnet I love the look of those rear spoilers. Quote Link to comment Share on other sites More sharing options...
