Smoke_U Posted May 28, 2010 Share Posted May 28, 2010 (edited) Edit by Homer: This is stipped out of another thread as it needs it's own discussion. Original thread is here: http://www.mkivsupra.net/vbb/showthread.php?t=218904 I have the same problem. Was told its ither boost cut or bad pluggs. Iv cheked the plugs and tapped the "pin" on 2 of them down to 0,8mm (i think it was) but have not had the chance to floor it yet. I was told the spark kan be blown out if thers to bigg of a gap. Mines a automatic bpu, 1,2 bar boost + chipp Edited May 28, 2010 by Smoke_U (see edit history) Quote Link to comment Share on other sites More sharing options...
Smoke_U Posted June 19, 2010 Author Share Posted June 19, 2010 I have the same problem. Was told its ither boost cut or bad pluggs. Iv cheked the plugs and tapped the "pin" on 2 of them down to 0,8mm (i think it was) but have not had the chance to floor it yet. I was told the spark kan be blown out if thers to bigg of a gap. Mines a automatic bpu, 1,2 bar boost + chipp Tryed floring it on the motorway, the problem is stil there att 4900-5000rpm in 3 gear. But if i accelerate slowly in 3 gear, the problem dosn´t apear. I can rev it to the redline. I se what hapends when i change al 6 Iridium plugs:rolleyes: Does anny one know if this is damaging the engine...? its quite a jerk... (sorry for my bad speling - S.) Quote Link to comment Share on other sites More sharing options...
Homer Posted June 19, 2010 Share Posted June 19, 2010 Does it only occur if it's happening while at full boost for a few seconds or is it occuring whiule boost is building? What plugs do you have? Which FCD model? BTW, please start a new thread for the same reasons as above, the issue Rob and Mikley have is different as they are a lot more than just BPU. Quote Link to comment Share on other sites More sharing options...
Smoke_U Posted June 23, 2010 Author Share Posted June 23, 2010 Does it only occur if it's happening while at full boost for a few seconds or is it occuring whiule boost is building? What plugs do you have? Which FCD model? BTW, please start a new thread for the same reasons as above, the issue Rob and Mikley have is different as they are a lot more than just BPU. It only hapends at full bost in 3rd gear (auto) at around 5000rpm for a split sec. Not while boost is charging! I nowtist some thing this morning as i drove to wourk. I´v notist that it´s ben gurgeling a lot out the exaust = to much fuel or to much unburnt fuel. But after a ful blast inkl the famus powerlos, the car sounded normal and drove a bit smother...i think... After anoter blast the unusual gurgeling was bak agen. Is it posible for the ECU to lose its tuned setings?... thus altering fuel setings and ignition timing:search: Question: Is the stock ECU a self lerning one or could posibly my chip be one? Mine is caled Superchip. Sorry but dont know how to start a new thread, im a newbe remember:D Quote Link to comment Share on other sites More sharing options...
Homer Posted June 23, 2010 Share Posted June 23, 2010 I've moved your posts out to a new thread Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted June 23, 2010 Share Posted June 23, 2010 It only hapends at full bost in 3rd gear (auto) at around 5000rpm for a split sec. Not while boost is charging! I nowtist some thing this morning as i drove to wourk. I´v notist that it´s ben gurgeling a lot out the exaust = to much fuel or to much unburnt fuel. But after a ful blast inkl the famus powerlos, the car sounded normal and drove a bit smother...i think... After anoter blast the unusual gurgeling was bak agen. Is it posible for the ECU to lose its tuned setings?... thus altering fuel setings and ignition timing:search: Question: Is the stock ECU a self lerning one or could posibly my chip be one? Mine is caled Superchip. Sorry but dont know how to start a new thread, im a newbe remember:D Sounds like boost cut mate. Is this happening at just above 1 bar? Quote Link to comment Share on other sites More sharing options...
Smoke_U Posted April 9, 2011 Author Share Posted April 9, 2011 Could it be that the fuel has a lean spot so that the engine shuts down? Quote Link to comment Share on other sites More sharing options...
Smoke_U Posted April 9, 2011 Author Share Posted April 9, 2011 Sounds like boost cut mate. Is this happening at just above 1 bar? I don´t think its boost cut because, after the split second of power loss, the boost is back up on 1.2 bar and rockets away endlessly with full power. BUT....this just struck my mind. Could my boost gauge be of? = showing me 1.2bar but in reality it could be more? Quote Link to comment Share on other sites More sharing options...
Smoke_U Posted April 18, 2011 Author Share Posted April 18, 2011 Heeellooooo in the dark!! *eco* Quote Link to comment Share on other sites More sharing options...
Nic Posted April 19, 2011 Share Posted April 19, 2011 Heeellooooo in the dark!! *eco* The thread is nearly a year old. Quote Link to comment Share on other sites More sharing options...
Smoke_U Posted April 26, 2011 Author Share Posted April 26, 2011 sooo! stil have the same problem after taking the car out from the winter garage. Quote Link to comment Share on other sites More sharing options...
