dani_r Posted June 22, 2010 Share Posted June 22, 2010 As above really! 245/40/18 too much for a 9.5j? Any thoughts appreciated Many thanks Dan Quote Link to comment Share on other sites More sharing options...
Jamesy Posted June 22, 2010 Share Posted June 22, 2010 I have a 265 on my 9.5j rear wheel and they're a bit stretched Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 22, 2010 Share Posted June 22, 2010 245 is the smallest but will be okay, the optimum sizes are 255 or 265 with 275 being the max to fit to a 9.5 inch wide rim Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted June 23, 2010 Share Posted June 23, 2010 Was going to say, my fronts are 9.5 and I have 255's on then with no probs at all Quote Link to comment Share on other sites More sharing options...
Guest ed_jza80 Posted June 23, 2010 Share Posted June 23, 2010 ive got 245 on 9.5 at the front. works just right. we tried 235 and it just looked stupid cheers ed Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 23, 2010 Share Posted June 23, 2010 (edited) I did recently post a tyre width chart with all this data on, i'll have to dig it out if i can find it Here you go Rim width---Min tyre width---Ideal tyre width----Max tyre width 7.0 inches-----195 mm--------205 or 215 mm-----------225 mm 7.5 inches-----205 mm--------215 or 225 mm-----------235 mm 8.0 inches-----215 mm--------225 or 235 mm-----------245 mm 8.5 inches-----225 mm--------235 or 245 mm-----------255 mm 9,0 inches-----235 mm--------245 or 255 mm-----------265 mm 9.5 inches-----245 mm--------255 or 265 mm-----------275 mm 10.0 inches----255 mm--------265 or 275 mm-----------285 mm 10.5 inches----265 mm--------275 or 285 mm-----------295 mm 11.0 inches----275 mm--------285 or 295 mm-----------305 mm 11.5 inches----285 mm--------295 or 305 mm-----------315 mm 12.0 inches----295 mm--------305 or 315 mm-----------325 mm 12.5 inches----305 mm--------315 or 325 mm-----------335 mm Edited June 23, 2010 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Geo Posted June 23, 2010 Share Posted June 23, 2010 O nice Chart, that wil help out alot dude, Should be a Sticky?? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 23, 2010 Share Posted June 23, 2010 Its fine, Im running a 10" with a 235 on lol Quote Link to comment Share on other sites More sharing options...
Guest ed_jza80 Posted June 23, 2010 Share Posted June 23, 2010 im sure it looks awesome Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 23, 2010 Share Posted June 23, 2010 im sure it looks awesome I have my doubts and don't understand the stretched tyre scene i've either got old or just like certain things like tyres to be spot on Quote Link to comment Share on other sites More sharing options...
4packet Posted June 23, 2010 Share Posted June 23, 2010 I'm running 235/45/17 on a 9.5j track rim. Not out of choice (cost), but it works OK and doesn't look 'too' strange. Took me a while to convince the tyre fitter it was a good idea however. Quote Link to comment Share on other sites More sharing options...
James Posted June 23, 2010 Share Posted June 23, 2010 I think that on something like a Supra, I wouldn't run a stretch like that. It seems to work ok on the Dub scene, where it's more of a low and slow effort. On my old Golf I had 215/40/18 on a 9J and that gave quite a good stretch, but I wouldn't do that on a Supra. Here's a pic: http://i1.bebo.com/046b/14/large/2008/11/26/01/20468910a9504580589l.jpg Quote Link to comment Share on other sites More sharing options...
dcarrter21 Posted June 23, 2010 Share Posted June 23, 2010 i ran a 215/45/17 on a 9.5j when i was stuck for tyres. very intresting on a ttbpu! Quote Link to comment Share on other sites More sharing options...
jevansio Posted June 23, 2010 Share Posted June 23, 2010 Toyo rate the R888 as being 295 max on a 10" rim, sure that's what Paul Whiffin races on with his TA car. EDIT this isn't for the OP, but more the table although being a good guide, specific tyres may go outside those values Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted June 23, 2010 Share Posted June 23, 2010 You can probably fit a 225 on a 9.5j, and a 295 as well. But depends on what you are using the car for and if you just want to show off (or the other way around). The supra came on 9.5j rear with 255 on it. I would stick with that. Toyota did the work and mindgames when they build the car, why do it all again? (unless you just want a certain look and don't mind the cars purpose) Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 23, 2010 Share Posted June 23, 2010 Toyo rate the R888 as being 295 max on a 10" rim, sure that's what Paul Whiffin races on with his TA car. EDIT this isn't for the OP, but more the table although being a good guide, specific tyres may go outside those values I agree with you Jay and your example proves there will be varients but the size you mention is a small differance unlike some of the sizes mentioned by others which are miles off. Quote Link to comment Share on other sites More sharing options...
jevansio Posted June 23, 2010 Share Posted June 23, 2010 I agree with you Jay and your example proves there will be varients but the size you mention is a small differance unlike some of the sizes mentioned by others which are miles off. Defo , Quote Link to comment Share on other sites More sharing options...
