UZA80 Photos they *should* have printed but didnt...
Guest ed_jza80
Guest ed_jza80
Which magazine, dare I ask?
High Performance Imports, Australia :rolleyes: Feb or March issue i think.
specs, yeah, er specs.... trying to stay lazy and just copy info from all over the place into one coherent list...
CAR
Year: 1995
Make: Toyota
Model: JZA80 Supra
Body colour: Originally original colour code 752 (baltic blue), slightly modified with zirallics and tone changes, but the same base colour/hue remains unchanged
ENGINE (Now OLD engine, see new engine at the bottom): 2000 model Toyota 4.0L 1UZ-FE VVT-i Naturally Aspirated
Maximum power output (including RPM): About 510-520BHP @ 9,300rpm
Engine Lubrication System: Modified Wetsump + Accusump Accumulator
Engine Cooling System: Stock
ENGINE INTERNALS
Crankshaft: OEM Forged Crank, Ground, Cryo'd and Peened
Conrods: Argo H Beam Forged Rods, ARP Bolts
Bearings: ACL Race with HM Elliot Coatings
Pistons: SPS Custom Forged Pistons
Static Compression Ratio: 11.8:1
Rings: 'Total Seal' 1.5/1.5/3.0mm
Camshaft(s): Waggot Cams, Custom VVT-i specific grind #144
– Lift: 0.408"
– Duration: 321* advertised, 257* @ 0.050"
Lifters: Shim Under Bucket 31mm dia
Rocker Arms: NA
Cylinder heads: Ported stock heads 280cfm @ 0.500"/28" H2O, ARP Studs
Valve springs: 'Performance Springs' valve springs, 0.445" lift capable
Valves (and Size): OEM VVT-i valves
115 Intake: 33.5mm
116 Exhaust: 29.0mm
INDUCTION
Manifold: Custom Fabricated ITB Manifold
Air intake: Twin Custom 4"
Filtration system: Uni Filter
Inlet pipe: Twin Custom 4"
Silicon hoses: 4"
Throttle Body (Type/Size): x8 48mm ITB's, modified rb26det units with custom OS butterflies and machined shafts (EFI Hardware)
Plenum Chamber: Custom Carbon Fibre Dual Entry Balanced Plenums
FUELLING SYSTEM
Fuel storage: OEM Fuel Tank
Fuel supply: Walbro in tank lift pump, Custom Swirl/Surge Pot 3.5L, Bosch 440 external pressure pump. -6AN/Speedflow Supply Lines, Custom HighFlow Rails, x8 440cc/min injectors running at 60psi rail pressure, Aeromotive adjustable fuel reg, OEM Return Lines, Fuel cooler on return line into swirl tank.
Fuel filtration: Aeromotive -6AN Inline Filter
Ignition System: OEM Coil on Plug Ignition
Engine management system: Autronic SM4
Who did your engine work? 90% of engine work and parts development done in our backyard shed as an ongoing project, with individual tasks outsourced, including bottom end work by Jason Myers @ JMR Fabrications and Mark Yager @ Yager Performance Engines, head work by Mark Florrimal @ Speedworks, Cam Development by Peter Waggot @ Waggot Camshafts. Pullies and Balancers by Ross @ Ross Tuffbond, Individual Component Fabrications and Modification by Linden Martin @ Roadrunner Fabrications.
EXHAUST SYSTEM
Extractors/headers: Custom Made (JMR Fabrications) Tuned Length 4-1 Extractors with Edelbrock merge collectors. 36" primary length, 1 7/8" primary dia. 3" collector and secondary pipes. Mandrel bent, ceramic coated.
Catalytic converter: Twin 3" metal cat
System’s construction: 3" Stainless twin exhaust with crossover, twin entry rear single muffler
Mandrel bent (Y/N): Yes
Resonator(s) (no/brand): No
Muffler (make/model): Unknown brand twin 3" entry, single 4" outlet
Tip(s): 5" tip
DRIVETRAIN
Gearbox: Currently OEM Toyota W58 5sp manual (aka the hand grenade) kept to sort out gear ratios during testing. We’re looking at a Holinger 6sp sequential to replace this gearbox shortly
Pressure plate: Tilton 7.25" see below
Clutch type: Tilton 7.25" triple plate (Ex NASCAR Clutch modified to take new twin plate rally clutch plates)
Flywheel: Custom Alloy 2.5kg flywheel with separate ring gear (Geoff O'Toole @ GT Tooling).
Driveshafts: stock
Axles: stock
Tail-shaft: stock
Differential: Modified JZX90 Chaser differential grafted into the JZA80 Supra subframe with Kaaz 2-way LSD installed. The JZX90 runs a traditional 'G' series 8" crown and pinion which opens up ratio options. There are no ratios available for the standard 'A' series JZA80 differential
Final-drive ratio: 4.88:1
BRAKES
Front: 355mm Brembo F50 4 piston calipers on custom brackets
Rear: 330mm Brembo GT3 4 piston calipers on custom brackets
Booster: Stock
Brake pads (F/R): Hawk
Lines: TRD
SUSPENSION/CHASSIS BRACING
Front suspension (brand/model, struts/springs/coil-overs): Tein HA Adjustable Coilovers 14kg/cm
Rear suspension: Tein HA Adjustable Coilovers 12kg/cm
Strut brace (F/R): NA
Swaybars (F/R): Whiteline 30mm/20mm front/rear
Amount lowered from standard: 50mm
WHEELS AND TYRES
Brand/make (F/R): Work
Model: XT7
Dimensions: 18x9.5" all ‘round
PCD: 5 x 114.3mm
Offset: +30front +20rear
Front tyres: 245/40/18
Rear tyres: 275/35/18
CAR’S INTERIOR
Front seats: Driver's Sparco Pro2000 + Sabelt 6 point harness. Passesnger Stock
Rear seats: Stock
Steering wheel: Sparco Deep Dish Leather
Gearknob: Razo Seude
Tuning pedals: OEM Sports Option
Gauges: Autometer ProComp Oil Pressure and Water Temp
Other: Independent Shift Indicator
IN-CAR ENTERTAINMENT (ICE)
Stereo gear: Stripped Out
EXTERIOR
Front bar: OEM with Large Custom Carbon Fibre Air Dam
Lip: Unknown Brand Remade in Carbon Fibre
Bonnet: OEM + Aerocatch Latches
Side skirts: Top Secret
Rear apron: Veilside
Rear bar: OEM
Spoiler(s): Removed and holes welded
Paint (brand/colour): ProTec Custom Colour based on original OEM Code 752 (baltic blue), slightly modified with zirallics and tone changes, but the original base colour/hue remains unchanged
Other: Front and Rear arches rolled and flared around 14mm to clear 255/285 track slicks
And these are the specs of the new engine that we're fitting up at the moment...
2UZ iron block out to 96mm bore (+2mm OS)
1UZ crank offset ground and double nitrided 78.5mm (4mm de-stroker crank)
Final capacity 4.6L, est rpm limit around 10,500rpm (?+600bhp)
mains line bore, decks milled to mains tunnel axis
Custom full cromo crank girdle with ARP studs, plus tied to sump skirt
Lentz 6.0 SBC Nascar Custom rods on Honda 1.888 custom Clevite bearings (calico coated)
Custom CP X-forging box pistons 12:1 CR
45thou (approx) piston/head clearance cold (with CNC matched chambers to piston profile)
51thou Cometic 98mm gaskets
diamond cut 'Smith's Profile' valves and seats (farken expensive!)
Waggot camshafts 257 @ 50 (about 322deg base) and 437 lift INTAKE
Waggot camshafts 257 @ 50 (about 319deg base) and 408 lift EXHAUST
re-clearanced lifter valley and bucket bores for new cam lobe clearance
'Performance Springs' valve springs (can *just* squeeze 440 lift into these!)
ARP AM4.950-1LB heads studs (NOT Lextreme studs... dont start me!)
custom 4 stage (3+1 aux pump) dry sump, inc pan, pump brackets etc etc
Ross underdrive metal jacket race balancer with dry sump mandrel and gears
Ross custom pully set for idler, alt, and dry sump pump
new seals, gaskets, idler/belt bearings, belts etc etc
:sex::sex: ...thank god finally I had the biggest orgasm of my life ... need to take some rest and charge my batteries before I can see these pics again. I want one ... I want one .... I want one of these sex toys!!!
Coming to the car, its one great job .... why the hell toyota do something like this rather than an LFA which nobody can buy!
Oops sorry came out again ... :innocent: will continue later if I can hold on for longer .... :taped:
