Whining and rattle sound after clutch install
Guest @di
I have now have the clutch installed by a speed shop, I have now notice a winning sound after the clutch was replaced with the OEM flywheel, OEM clutch and RPS stage 2 pressure plate. The Release Bearing and Pilot Bearing was also changed.
The winning sounds most is in the first gear and the second one, and when the car is in neutral gear, and also in the reverse. I can hear rattle when shifting between the gears. But gears goes in nicely.
The speed shop says this all is normal and it should be like this, but this was not before, I don’t believe them they most have done something wrong.
Thanks
Edited by @di (see edit history)
