a very big thank you to paul/whifbitz
mikeyh
what did he help with or should we leave that to our imginations :p
i recently brought a single and i was having some issues with it :rolleyes: paul managed to get to the bottom of it very quickly, he was even nice enough to drop it over to ryan so it can be mapped.
top notch service i couldn't of asked for more:)
sweet as hope running spot on mate :)
I see you've now got rid of the avatar pic which makes this post:
Could the work in question have anything to do with the dustbin-sized turbo attached to the engine in your avatar pic?
a bit redundant...
For all that didn't see it before, the turbo was huge, okay?!
I checked over the map and noticed the autobox control was turned on so it was still retarding the igntion timing at the autobox shift points causing it hold back massively. One click on the laptop, problem fixed, I wish it was always that simple! So I'm presuming the car used to be an auto at some point?
Simple solution and one happy customer :) Robs car was an auto originally, AFR did a 6spd conversion on it (edit: too slow!)
If it was rob wilds old car then yes I understand dude did a manual conversion on it?!
A excellent gun metal grey example with tte wheels?
it certainly is rob wilds old car:d
dude did do the 6 speed conversion shame it wasn't noticed earlier:rolleyes:.
No probs Mike, glad it was an easy fix in the end, nice when its something simple. Should be even better after a remap as well, could do with running some extra booooooost, missing 100bhp or so there easy!
thanks again paul you will definatly be geting my future buisness need to save some pennys and go to the next stage.
hopfully ryan will get it all sorted while im away on holiday im sure the extra boooooost will make a massive difference:eyebrows:
That's a very nice example of a supra you have there and I can tell u no expense has been spared.
thanks for your comments:) i cant take the credit though it was rob who did all the work.
hopfully ill beable to take it on to the next stage just need to save some more pennys:eyebrows: if everything goes to plan shouldn't be that long
