Stonkin Posted June 22, 2010 Share Posted June 22, 2010 Hi guys, For a while ive wanted to replace how my battery is connected. On the negative side of the battery it has a green screw connection (so it can be quickly disconnected) that goes on the terminal and this then connects to the negative lead running to the chassis earth. Sometimes when starting the car if it has been switched on and off a few times it wont start and just clicks. This isnt the starter problem as it has all been reconditioned. When it does it i just wiggle the negative lead and it starts fine. Its almost as though there are to many links on this connection and its got a bit old and not making a good join. So, i want to remove this and just have a straight connection from the chassis to battery. I've bought a new negative lead but i need to get hold of a battery terminal connection and it needs to be for the smaller battery connector type. Have tried halfords and they only do the normal larger type for UK batteries. Can anyone recommend somewhere, preferably where i can order online? cheers Christian Link to comment Share on other sites More sharing options...
paul mac Posted June 22, 2010 Share Posted June 22, 2010 cant recomend anywhere on line but when i did a battery relocation i went to a local auto electrician who sold me the bits i needed (for peanuts) and offered advice as well Link to comment Share on other sites More sharing options...
Stonkin Posted June 22, 2010 Author Share Posted June 22, 2010 cheers Paul. Been googling as well (which i probably should have done before!) and found a couple of places, gona call them after lunch Link to comment Share on other sites More sharing options...
Stonkin Posted June 22, 2010 Author Share Posted June 22, 2010 Just ordered from here incase anyone ever needs one quickly. Is due tomorrow and only a couple of quid for postage to http://www.electricalcarservices.com/japanese-c-55_227.html Link to comment Share on other sites More sharing options...
Scott Posted June 22, 2010 Share Posted June 22, 2010 How hard is it to remove the entire earth lead? Is the Earth cable just bolted onto the chassis? I extended mine but I would rather just replace the whole lot if it was easy enough. It looked a little more complicated last time I looked IIRC, I might have been over analysing it though. Link to comment Share on other sites More sharing options...
Stonkin Posted June 22, 2010 Author Share Posted June 22, 2010 Just goes from the negative connection on the battery to the chassis mate, just over a foot long. Screws to the chassis by an 'eye ring' connection on the end of the lead. Link to comment Share on other sites More sharing options...
Scott Posted June 22, 2010 Share Posted June 22, 2010 Ideal, cheers bud Link to comment Share on other sites More sharing options...
