Whats this noise on the van?
Stonkin
On the way home tonight i noticed a whirring noise when i applied the brakes. The noise slowed down dependant on vehicle speed. You could only hear it when coming to a standstill from about 15 or 20 mph.
I took the front wheels off tonight to check it over and found when you turn the disk on the passenger side it makes a similar noise. The cv joints all looked ok.
Drivers side
Passenger side
Is it the drive shaft that has gone?
Cheers
Think you might be right Peter :)
So the only things i can narrow it down to is...
CV joints?
Wheel bearing? could a bearing sound like that? I did the test by holding the wheel at opposite sides and woggling it to see if any play and didnt notice any.
Drive shaft?
Pad wear indicator??
The Audible type ( little metal bar on the inside pad ) might be hitting the disc tell you to change the pads?
Pads were changed 2 months ago mate, i checked them and there still very new. Someone coming over monday with a few possible parts. Can only really think of cv joint or drive shaft
