supra mkiv Posted June 21, 2010 Share Posted June 21, 2010 so the engine will not be long before I have everything at home then assemble the work can begin on .. is there anyone at eh a supra engine weighs? Around torque wrench some who know the am-pro torque wrenches? can see that the connecting rod cap have to be tightened to 29nm and 90 degrees. but have a torque wrench which can tightened 30 nm. is very important that they are excited to 29nm and 90-degree or can i tighten them 30nm and 90 degrees whitout there is no harm to the engine at the longere shot?? Link to comment Share on other sites More sharing options...
vase Posted June 21, 2010 Share Posted June 21, 2010 I don't quite follow what you're asking but I weighed my 2jzgte complete engine without transmission and it was 240kg. 2jzgte engine weight 240kg Link to comment Share on other sites More sharing options...
supra mkiv Posted June 21, 2010 Author Share Posted June 21, 2010 it is because I am looking at an engine stand that I can make the engine on. and can keep an engine which weighs 500 kg. so therefore I should just know the weight of the engine and because I ask for a torque wrench is because I can get such a torque wrench which can range from 30nm -> 350nm so therefore I just had to hear about what happened by tightening connecting rod cap 30nm and 90 degrees instead of the recommended 29nm and 90 degrees Link to comment Share on other sites More sharing options...
supra mkiv Posted June 22, 2010 Author Share Posted June 22, 2010 nobody there can help me with my last question? Link to comment Share on other sites More sharing options...
Nodalmighty Posted June 22, 2010 Share Posted June 22, 2010 nobody there can help me with my last question? I would be VERY surprised if you could angle tighten each bolt to exactly 90 degree's, so 1nm probably won't be an issue. Link to comment Share on other sites More sharing options...
supra mkiv Posted June 22, 2010 Author Share Posted June 22, 2010 I say many thanks for your help, no I have that same thought, but rather ask once too much than too little Link to comment Share on other sites More sharing options...
