wallis Posted June 21, 2010 Share Posted June 21, 2010 Really need a dyno doing where the hell is the closest to take it from Lincoln, I can't find any nearby that have dynos for cars over 400bhp any help guys??? Cheers matt Link to comment Share on other sites More sharing options...
ellis Posted June 21, 2010 Share Posted June 21, 2010 That's always fun round here mate - be prepared to travel for a decent one. Do you need tuning done? Link to comment Share on other sites More sharing options...
jackso11 Posted June 21, 2010 Share Posted June 21, 2010 Corton-Millers, near skegness http://www.corten-miller.co.uk/ Link to comment Share on other sites More sharing options...
Swampy442 Posted June 21, 2010 Share Posted June 21, 2010 +1 Corten Miller, although its a shit road to get there! Link to comment Share on other sites More sharing options...
wallis Posted June 21, 2010 Author Share Posted June 21, 2010 That's always fun round here mate - be prepared to travel for a decent one. Do you need tuning done? Basically I've always been happy with the performance, even after I went bpu, maybe because I use the car rarely I have not noticed but my boost gauge only goes to 0.6-0.8 on full boost, but drives fine no probs, when I went bpu I supplied the 50.5mm restriction ring to be fitted at the place who did the exhaust system, and another lad said he had fitted/or there was already a fcd fitted so everything was fine and the first gauge went to 1-1.2bar after I went bpu about 3years ago, I changed the current gauges 2 years ago but didn't really notice the lower boost readings untill Sunday. After closer inspection on Sunday I can't find any fcd on the car and think now that maybe the first gauge was wrong and that the only thing restricting the boost is the rr which means it must only be running at 0.8 (stock) otherwise fc would occur without a fcd. In a nut shell I wanted to get the car dyno to see what it's running at and go from there, I'm thinking I better get a fcd and boost controller fitted and get the car set up correctly, maybe I should just get this lot done before I go and get it dyno'd afterwards? Link to comment Share on other sites More sharing options...
Stonkin Posted June 21, 2010 Share Posted June 21, 2010 You could always pull the passenger carpet back and see if a fcd is fitted, at least then you will know and will only take 5 mins to check Link to comment Share on other sites More sharing options...
jackso11 Posted June 21, 2010 Share Posted June 21, 2010 I have a fcd and restrictor ring fitted and without a boost controller it basically runs stock boost. Depends on the diameter of your ring. Link to comment Share on other sites More sharing options...
jackso11 Posted June 21, 2010 Share Posted June 21, 2010 If you go to see Corton-Miller's and you see Tom Corton-Miller, tell him Adam says Hi. I went to uni with him Link to comment Share on other sites More sharing options...
Stonkin Posted June 21, 2010 Share Posted June 21, 2010 Depends on the diameter of your ring. and i guess thats dependant on you having a curry the night before or not Link to comment Share on other sites More sharing options...
greeny Posted June 21, 2010 Share Posted June 21, 2010 Really need a dyno doing where the hell is the closest to take it from Lincoln, I can't find any nearby that have dynos for cars over 400bhp any help guys??? Cheers matt Im from cleethorpes and usually travel to leeds with the MR2, RS tuning. There's a few round here, scunthorpe/grimsby/hull, but all ive been to arent really much use. Paul @ Rs-tuning is reccomended. Cheeers. Link to comment Share on other sites More sharing options...
Swampy442 Posted July 7, 2010 Share Posted July 7, 2010 Did this rolling road go ahead? Any results? Link to comment Share on other sites More sharing options...
