Pre-facelift trac ECU and ABS.
tbourner
Questions:
1. Does the TC ECU (the one on the left in the footwell) also control the ABS?
2. Will my car fail the MOT now I've taken out the aforementioned ECU and therefore may not have working ABS; assuming an affirmative to Q1?
2b. Is it not just the ABS warning light that gets checked?
I was under the impression facelift and pre-facelift had the ABS control in a different place? Not sure why I think that!!
No they are in the same place, but have a different ABS control unit. You can bin the trac ECU no problem, although if you have an auto it may make your gearchanges a bit more abrupt.
